Author Topic: Ceramic metal halide uv emission  (Read 1841 times)
marcopete87
Ceramic metal halide uv emission « on: October 31, 2020, 07:08:18 AM » Author: marcopete87
Hi all, some years ago (7-8) one of MH CDM lamps i ordered arrived with external glass broken (but intact tube), i kept it.
It is an 150W Philips master cdm G12 lamp.
Due this period, i was wondering if is it advisable run with broken external glass to produce UVC and ozone.
I was wondering about run with 70W magnetic ballast to stuck it with only mercury emission in protected luminarie (otherwise, i will use an 150w ballast).
Re: Ceramic metal halide uv emission « Reply #1 on: October 31, 2020, 03:44:51 PM » Author: Medved
The UV emission is similar to other discharges
The problem will come mainly from the arctube seals being exposed to oxygen, the ceramic ones are even more sensitive than the quartz ones.
marcopete87
Re: Ceramic metal halide uv emission « Reply #2 on: November 01, 2020, 02:49:30 AM » Author: marcopete87
Thank you Medved for the info!
