Author Topic: Would normal sockets work for hps or psmh lights?  (Read 2840 times)
Bulbman256
Mad Max
Bulbman256
Would normal sockets work for hps or psmh lights? « on: October 27, 2020, 05:15:15 PM » Author: Bulbman256
Hey guys, im currently looking into getting some hps ballasts and i did not want to break the bank buying pulse rated sockets and was wondering if it was okay to use normal ones for a 70-150w application.
Re: Would normal sockets work for hps or psmh lights? « Reply #1 on: October 27, 2020, 06:21:14 PM » Author: wide-lite 1000
Not sure how long regular sockets would or wouldn't last. Check these out  : https://www.ebay.com/itm/Leviton-70045-Porcelain-Medium-Base-4KV-Wire-9-with-Bush-Socket-28113/271466671995
Re: Would normal sockets work for hps or psmh lights? « Reply #2 on: October 27, 2020, 06:37:45 PM » Author: funkybulb
  50 to 150 watts with HPS chokes and 120 volt OCV
   I am sure the manufacture use standard sockets
   Only time it would flash over if socket is dirty.
Xytrell
Re: Would normal sockets work for hps or psmh lights? « Reply #3 on: October 28, 2020, 10:53:38 AM » Author: Xytrell
I've used standard sockets for years with no ill effects. I think A ceramic socket would in theory fair better than a plastic one.
Re: Would normal sockets work for hps or psmh lights? « Reply #4 on: October 29, 2020, 12:27:15 PM » Author: Medved
I think a ceramic, no paper insulation, should be fine.
Second order for the lower wattages (35 and 50W) could be the plastic, but only base down, never base up, better not horizontal (the lamps have their center of gravity quite far away from the socket and are rather heavy, compare to incsndescents; and definitely will be running hotter at the base than CFLs or LEDs)
Never use sockets with just paper insulation, the paper can not stand the ignition voltage.
Re: Would normal sockets work for hps or psmh lights? « Reply #5 on: October 29, 2020, 06:53:35 PM » Author: sol
I personally never use any socket other than pulse rated for PSMH or HPS, period. Probe start, I use only ceramic, nothing else.
Re: Would normal sockets work for hps or psmh lights? « Reply #6 on: October 29, 2020, 09:03:18 PM » Author: joseph_125
I think pretty much all my mogul sockets are pulse rated. As for medium base lamps, I'll use standard sockets in some cases. My only requirement is that they be ceramic.
Re: Would normal sockets work for hps or psmh lights? « Reply #7 on: October 29, 2020, 09:06:42 PM » Author: sol
The only exception I can think of for mogul sockets are the 3-way floor lamp ones.
Re: Would normal sockets work for hps or psmh lights? « Reply #8 on: October 30, 2020, 11:36:14 AM » Author: Mandolin Girl
We have one of those, see here for the picture :bulbman:
Re: Would normal sockets work for hps or psmh lights? « Reply #9 on: October 30, 2020, 03:48:29 PM » Author: sol
Oh, it will work, but it is not pulse rated.
Re: Would normal sockets work for hps or psmh lights? « Reply #10 on: October 30, 2020, 08:12:51 PM » Author: joseph_125
Yeah I don't think I ever saw a pulse rated 3 way mogul lampholder, or one that doesn't have a integrated switch for that matter.
Of interest, it seems most newer incandescent vapour light fixtures have pulse rated sockets. Handy for use who like to run HID lamps in them but not really needed for most people.
Re: Would normal sockets work for hps or psmh lights? « Reply #11 on: October 30, 2020, 09:29:01 PM » Author: WorldwideHIDCollectorUSA
I also do have some mogul sockets that are ceramic but not pulse rated and are designed with high wattage incandescent lamps in mind and they are only single contact rated.
