Author Topic: In the US, why did 4 foot preheat fluorescents get replaced with rapid start?  (Read 2394 times)
In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « on: October 24, 2020, 06:57:54 PM » Author: WorldwideHIDCollectorUSA
I wonder why 4 foot preheat fluorescent lighting quickly fell out of favor to 4 foot rapid start fluorescent lighting in the USA while 4 foot preheat fluorescent lighting remained popular in Europe and the rest of the world?
mdcastle
mdcastle 26956281@N02
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #1 on: October 24, 2020, 07:07:12 PM » Author: mdcastle
The US has always placed importance on convenience. See also our early adoption and love for automatic transmissions and air conditioning.
Simply put it was irritating to flick on a light switch and wait for a preheat lamp and it was irritating to fix them when a lamp went out and you didn't know if it was a bad  lamp, bad starter, or a loose starter. We had some preheat fixtures and  more than once my father bought  some new tubes at the hardware store, then found it was a starter so had to run back to the store to get one of those.
(It's been a while but I thought I'd reply to a post to let people know I'm still around).
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #2 on: October 24, 2020, 07:21:41 PM » Author: WorldwideHIDCollectorUSA
I wonder why other preheat fluorescent lights stuck around such as can lights with PL bulbs?
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #3 on: October 24, 2020, 11:44:17 PM » Author: wide-lite 1000
Because the starters in those were usually integral with the lamp . If the fixture didn't light , try another lamp! No muss, no fuss.
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #4 on: October 24, 2020, 11:54:55 PM » Author: joseph_125
I think ballast topology was a factor too. F40 preheat ballasts for 120v required a autotransformer type ballast in order for the lamp to start and run reliably so it was fairly straightforward to add the auxillary windings for a cathode heating circuit. The other reason is preference, the flashing on typical of a preheat light was seen as unsightly to many compared to the smooth startup of a rapid start light.
In countries with 240v power, preheat lasted a lot longer as the higher line voltage meant that F40 preheat ballasts was a simple choke ballast, and a rapid start style setup would mean extra cost and complexity. That's the same reason why preheat remained common for smaller lamps like 2ft and under lamps and PL lamps. Still preferences meant that trigger start ballasts were made for 2ft lamps.
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #5 on: October 25, 2020, 09:11:10 AM » Author: Medved
And why RS never took off in Europe?
It would mean extra losses. And in Europe were (since 70's energy crisis?) quite strict requirements for ballast efficiency, so practically anything but a simple series choke would not pass or become too expensive to pass the regulations.
Plus the advent of T8 meant the ballast would have to provide even higher voltage for ignition, which would mean even higher losses and/or cost to anything but preheat. Plus tye T8 have really no selectivity in igniting only when electrodes are hot, they tend to either not start at all, or ignite with still cold electrodes, which would shorten their life a lot.
Plus at some moment a safety requirement came, requiring the lamps to not ignite unless both ends are in their sockets (so when you insert only one end and touch the pins on the other side, no current is allowed to flow). Pretty expensive sockets when you have OCV and electrode heating on one side able to ignite the discharge - you would need complex power cutout sockets for that.
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #6 on: October 29, 2020, 06:49:32 AM » Author: funkybulb
   2 lamp rapid start base off  1 lamp preheat ballast and they
  Added 3 windings for cathode heating and a leading cap to run both lamp just right at 200-220 volt OCV.
  This one of reason why there not enough OCV to fire a  8 foot modded slimeline shunted on rapid start.
Men of God
jiachao.wei.71 chao_813975447 UChyTpXvlQ8ZCfBPP_lJjubg chao990613
Re: In the US, why did 4 foot preheat fluorescents get replaced with rapid start? « Reply #7 on: December 07, 2020, 09:51:06 AM » Author: Men of God
中国在1950年代和美国同时应用过快速启动型镇流器,但是在1960年代就淘汰了,因为中国进行了升压工程,从110V升压到220V,所以全部废弃。但是日本和韩国有用快速启动型镇流器,韩国在很早也废弃了快速启动镇流器,因为韩国在1973年也开始进行升压工程,现在这种镇流器在亚洲只剩下日本还在用了,我也有几个美国和日本的镇流器,100V,120V和200V都有,200V镇流器可以直接用于220V不需要变压器就可以使用。
我不会英文,所以我用中文,请你们用翻译网站翻译我打的字!
I can't in English, so I in Chinese, please use the translation website to translate my words!
