Even in this case, would a power factor correction capacitor (no series capacitor) cause ballast overheating and failure if a 100v 50Hz ballast is operated on a 120v 60Hz supply? The high power factor lag type 100v 50Hz ballasts that I am considering importing have an integrated power factor correction capacitor.
I am considering the following ballast because it seems like it might be my closest solution to running North American 1000w H34 mercury vapor lamps on a 120v 60Hz supply without using any transformers at all and Japanese HF1000X mercury vapor lamps are electrically identical to North American 1000w H34 mercury vapor lamps:
https://www.jauce.com/yahoo-japan-shopping/item/lamps_22031/This one is a 100v 50Hz high power factor HX autotransformer ballast. I might be seeming to go for this one because the low power factor 100v 50Hz HX autotransformer ballasts have been discontinued and are harder to find and I mostly stumble across 200v ballasts that are either 50Hz or 60Hz when looking at Japanese HF1000X mercury vapor ballasts and I don’t want to have to pay extra costs to get a step up transformer just to get a ballast that can properly run North American 1000w H34 mercury vapor lamps.
