Author Topic: Old flourescent lamps changing color?  (Read 2636 times)
A2ZAlarms
UCn-UWLJRLZh8NA46vkc1jSQ A2Z Alarms
Old flourescent lamps changing color? « on: August 17, 2020, 10:20:44 AM » Author: A2ZAlarms
in my bedroom I have a rapid start 40w fixture with two Westinghouse black ended tubes. they started off as a really nice warm white color when i installed them but one has turned to a pinkish gross color.
anyone know how to fix this?
I don't dislike High quality led lamps, but vintage usually wins.
A2ZAlarms
Re: Old flourescent lamps changing color? « Reply #1 on: August 17, 2020, 10:24:01 AM » Author: A2ZAlarms
Here is a picture
Bulbman256
Mad Max
Bulbman256
Re: Old flourescent lamps changing color? « Reply #2 on: August 17, 2020, 11:02:04 AM » Author: Bulbman256
Here is a picture
feel like one of the tubes is suffering from air poisoning.
Re: Old flourescent lamps changing color? « Reply #3 on: September 06, 2020, 01:23:43 AM » Author: Medved
...and that means leaky seal, so a slow air leak...
Re: Old flourescent lamps changing color? « Reply #4 on: September 06, 2020, 10:21:04 PM » Author: RyanF40T12
You can try non acidic super glue around the end caps in hopes it seals any leaks that might be there, but no guarantees.  Could also be microscopic cracks in the glass.  Run it hard and to EoL as best you can!
