Author Topic: Strange CFL Startup Video  (Read 4173 times)
sss2008
Strange CFL Startup Video « on: February 16, 2009, 01:55:54 PM » Author: sss2008
The CFL that I have had running in my bedroom has shown odd behavior starting up recently. As you can see in this video, it takes about 20 seconds for it to produce any sort of useful light (no flickering and what not). This is the CFL I'm talking about: http://www.lighting-gallery.net/gallery/displayimage.php?pos=-27238
Video: http://s27.photobucket.com/albums/c154/SSS2005/?action=view&current=OddCFL.flv
This wound up being the last time this CFL would light up fully; it now lights up extremely dim and is showing striations. Good thing I took the video in time. ;)
lightman64
Re: Strange CFL Startup Video « Reply #1 on: February 16, 2009, 05:40:35 PM » Author: lightman64
It's pretty much dead dude. You probally should replace it. Sorry it went on you; but that was a cool video. There was a problem with the ballast or maybe it lost vacuum....
sss2008
Re: Strange CFL Startup Video « Reply #2 on: February 16, 2009, 06:31:54 PM » Author: sss2008
Yeah, I've already replaced it. It was pretty much useless when it started going dim and striating.
I'm leaning towards a ballast issue; the internal fuse popped when I tested it a few hours later in another fixture.
Re: Strange CFL Startup Video « Reply #3 on: March 26, 2009, 02:31:56 PM » Author: Medved
It could easily be loss of emitter, the usual consequence in these CFLs is ballast burning out (transistor's hard switching => they overheat and break to short).
Mercury Man
Re: Strange CFL Startup Video « Reply #4 on: March 27, 2009, 12:08:20 AM » Author: Mercury Man
What's interesting is that I have a CFL that did something very similar to this once...it was a CFL that ran in my hallway for about three years straight, 24/7, but then I took it out and replaced it with a different bulb.  I put the CFL in my closet light and the first ten times I turned it on, it did the same thing that is seen in this video.  However, after that, it lit up normally, and still does!
Mr. Big
Re: Strange CFL Startup Video « Reply #5 on: June 03, 2009, 01:01:30 AM » Author: Mr. Big
Beware of the glowing electrodes on GE lamps, i had a 26 watt one do this is exact thing, and next thing i know, burning plastic, and then take a look in my gallery for the rest!
Re: Strange CFL Startup Video « Reply #6 on: June 03, 2009, 03:54:56 PM » Author: Medved
Then it might be some bad soldering on the PCB - sometimes it conduct, sometimes not... I would expect the electrolytic filtering capacitor and/or some rectifier's diode, but check all soldering points...
