Author Topic: 35 watt or 18 watt low pressure sodium lamp  (Read 2313 times)
RadxD461
35 watt or 18 watt low pressure sodium lamp « on: August 05, 2020, 12:39:52 PM » Author: RadxD461
I really want a 35 watt or 18 watt low pressure sodium lamp for cheap.
Re: 35 watt or 18 watt low pressure sodium lamp « Reply #1 on: August 05, 2020, 03:38:35 PM » Author: joseph_125
The 18w and 35w lamps still seem to be fairly affordable on Amazon.
18 watt
35 watt
Metal Halide Boy
Re: 35 watt or 18 watt low pressure sodium lamp « Reply #2 on: August 06, 2020, 09:01:34 AM » Author: Metal Halide Boy
In genral, you will probably find a 35w or even 50w bulb cheaper than a 18w, from what I understand.
Re: 35 watt or 18 watt low pressure sodium lamp « Reply #3 on: August 06, 2020, 09:51:57 AM » Author: sox35
Cheap is a thing of the past for SOX lamps now, I fear. Get them while you can; now that production has ceased, once the existing supplies have gone, that will be it  :'(
