Author Topic: Minecraft?  (Read 12255 times)
Minecraft? « on: July 11, 2020, 12:47:53 PM » Author: wattMaster
Does anybody here like Minecraft? I just happen to have a server and everyone on Lighting Gallery is invited to it. If there's interest, I'll give the address.
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Minecraft? « Reply #1 on: July 11, 2020, 01:31:43 PM » Author: Binarix128
Well, I don't play it for a long time, but I like to create long train circuits in the creative mode. So yes, I'm interested.
Re: Minecraft? « Reply #2 on: July 11, 2020, 01:48:16 PM » Author: wattMaster
Here it is: 108.254.29.248
Bulbman256
Mad Max
Bulbman256
Re: Minecraft? « Reply #3 on: July 11, 2020, 01:49:58 PM » Author: Bulbman256
i do alittle bit but i play on swithc and it kinda bad and i dont have something that can run java
Re: Minecraft? « Reply #4 on: July 11, 2020, 01:50:46 PM » Author: wattMaster
I could make a non-java server, but I have no way to access it.
Binarix128
220V AC 50Hz, NTSC
Re: Minecraft? « Reply #5 on: July 11, 2020, 03:02:42 PM » Author: Binarix128
I can't connect to the server, there's a a login error.  :-\
Re: Minecraft? « Reply #6 on: July 11, 2020, 03:23:45 PM » Author: wattMaster
I can try to fix the problem and when it's ready I'll tell you.
CreeRSW207
Re: Minecraft? « Reply #7 on: July 11, 2020, 03:28:30 PM » Author: CreeRSW207
I have minecraft, I can play tonight around 7:45 ET.
Power Company: Eversource
Re: Minecraft? « Reply #8 on: July 11, 2020, 05:07:19 PM » Author: wattMaster
The server should be fixed now! I tested it with my router and it seems to work.
CreeRSW207
Re: Minecraft? « Reply #9 on: July 11, 2020, 05:11:02 PM » Author: CreeRSW207
I had some trouble joining my friend's world a few weeks ago, I'll try tonight.
Re: Minecraft? « Reply #10 on: July 11, 2020, 06:04:22 PM » Author: wattMaster
If it still doesn't work, then it could be a RAM problem. Luckily, I have a newer server coming in a few days, so it won't be too bad.
Re: Minecraft? « Reply #11 on: July 11, 2020, 08:32:35 PM » Author: wattMaster
Update: I'm having some technical difficulties. For now, I'll try to get a setup that works and then add another update.
Binarix128
220V AC 50Hz, NTSC
Re: Minecraft? « Reply #12 on: July 11, 2020, 09:54:01 PM » Author: Binarix128
Try creating the server with other versions like 1.15.0, 1.14.3 or 1.8.9
Re: Minecraft? « Reply #13 on: July 15, 2020, 05:06:15 PM » Author: wattMaster
Update: It finally works again. Go to "Add Server" in "Multiplayer" and enter anything for "Server Name." Then, enter 108.254.29.248 into "Server Address." You're done!
Binarix128
220V AC 50Hz, NTSC
Re: Minecraft? « Reply #14 on: July 16, 2020, 01:04:06 AM » Author: Binarix128
I'm still getting that login error when I try to connect with your server, and I can connect to other servers. Maybe the problem is with my launcher now.
