Author Topic: What is a "Wallpack" Light?  (Read 2225 times)
LightUpMyLife
https://www.facebook.com/ https://twitter.com/TedTa
What is a "Wallpack" Light? « on: July 07, 2020, 05:25:57 PM » Author: LightUpMyLife
How would you define a "wallpack" light?
CreeRSW207
Re: What is a "Wallpack" Light? « Reply #1 on: July 07, 2020, 05:41:52 PM » Author: CreeRSW207
A light fixture that is usually mounted on the side of a building. Here’s an example:
Power Company: Eversource
Xytrell
Re: What is a "Wallpack" Light? « Reply #2 on: July 07, 2020, 09:52:33 PM » Author: Xytrell
Is a sconce a wall pack, then? ^
Re: What is a "Wallpack" Light? « Reply #3 on: July 07, 2020, 10:03:06 PM » Author: sol
I would say no. For me, a wall pack is purely functional, a fixture most people would not necessarily say is beautiful. A sconce would be a more decorative fixture, usually with a lesser output than a wall pack.
Re: What is a "Wallpack" Light? « Reply #4 on: July 08, 2020, 03:48:59 AM » Author: joseph_125
Pretty much any utilitarian/commercial use wall mounted light like in the pic above. Usually has more light output than your typical residential wall mounted light and uses a HID or LED light source.
I believe the original Wallpacks were the old Holophane ones that had the ballast mounted externally above the fixture. The name has gotten genericised over the years to refer to any manufacturer's fixture with a similar form factor.
The closely related term, tallpack is I believe originally a RAB trademark but is often used to refer to those compact wallpacks that are taller than they are wide. Usually either low watt HPS/MH or LED. And in the case of the HID models, use a smaller medium based lamp.
« Last Edit: July 08, 2020, 03:54:37 AM by joseph_125 » Logged
