Binarix128
220V AC 50Hz, NTSC
High Intensity
This is one of my favorite videos for that clip alone.
Bulbman256
Mad Max
High Intensity
Bulbman256
Mad Max
Binarix128
220V AC 50Hz, NTSC
I've accually done that once with a cheap generic bulb i got for 75 cents.
I'll do that instead of smashing it for the next time.
At the transmitter site we have a "soda load" for the transmitters that uses sodium carbonate mixed in water as the load electrolyte.Can handle up to 750Kw.When the VSWR on the transmitter goes up-time to replace the electrolyte.It has arced in the load element chamber with the load electrodes-those had to be replaced.Wasn't there to see it blow!
Bulbman256
Mad Max
Binarix128
220V AC 50Hz, NTSC
Bulbman256
Mad Max
Binarix128
220V AC 50Hz, NTSC
Binarix128
220V AC 50Hz, NTSC
Thanks dude, if you have a higher amp breaker available then use it! or if you have two phases in your house then use both for more power! That reminds me i found the sequel to this video: https://www.youtube.com/watch?v=jS4GTACKETg
BTW here's its brother, as same as dangerous and its sequel.  Edit: In the second video the insulation of the heater seems to be asbestos.
« Last Edit: December 15, 2020, 08:16:33 PM by Binarix128 »
