Author Topic: H38 ballast and bulb wanted  (Read 4473 times)
Bulbman256
Mad Max
Bulbman256
H38 ballast and bulb wanted « on: June 21, 2020, 12:28:26 PM » Author: Bulbman256
Hey lg! so i am almost done moving and when i am i  will start a project that is a board with an 100w h38 mv ballast and lamp with a switch. I want to get a good classic merc bulb (nothing special, i don't really care for phosphor type and clear would also be acceptable. I just want something classic and dependable unlike the new china bulbs :sick:) Optional would be a proper h38 ballast that can run on 120v (i know i can use a 70w psmh ballast with ignitor delete but would like something completely spec correct.) Thanks for any offer althoug i dont ahve a paypal and the like so trading and if your near my area or coming thru kansas city then cash drop off/pickups would be good.  :)
Re: H38 ballast and bulb wanted « Reply #1 on: June 21, 2020, 02:14:25 PM » Author: joseph_125
I found a fairly affordable NOS Advance H38 on eBay.
Bulbman256
Mad Max
Bulbman256
Re: H38 ballast and bulb wanted « Reply #2 on: June 21, 2020, 04:16:34 PM » Author: Bulbman256
Thanks, i do need a recommendation of the lamp and i want a westy lifegard although phosphor type is not an issue or a a23 coated bulb ( the clears are hard to find and wayy pricer.) The Westy or other good reliable lamp is fine in clear too if that a little cheaper.
Re: H38 ballast and bulb wanted « Reply #3 on: June 23, 2020, 07:53:22 PM » Author: joseph_125
If you can't find vintage lamps, I would go with EYE/Iwasaki for modern lamps, they're pretty decent for modern lamps and you can get them in medium and mogul based, both coated and clear.
Bulbman256
Mad Max
Bulbman256
Re: H38 ballast and bulb wanted « Reply #4 on: June 23, 2020, 08:49:00 PM » Author: Bulbman256
Thanks man, probs not gonna find any old mercs avalible rn and i think i can get them on amazon, once i order the ballast all other parts can be bought at a hardware store or amazon. :) will get both clear and coated because both are awsome. :mv: 8)
Bulbman256
Mad Max
Bulbman256
Re: H38 ballast and bulb wanted « Reply #5 on: June 24, 2020, 07:40:44 PM » Author: Bulbman256
Thanks man, probs not gonna find any old mercs avalible rn and i think i can get them on amazon, once i order the ballast all other parts can be bought at a hardware store or amazon. :) will get both clear and coated because both are awesome. :mv: 8)
Well uhh i found some cheap a23 mercs so i may get them (i will because a23 mercs are COOL) The are from 06' but phillips a23 mercs from there are great. I also a will try to get clear mercs.
And this is my 100th forum post so :P
Re: H38 ballast and bulb wanted « Reply #6 on: June 24, 2020, 10:35:12 PM » Author: wide-lite 1000
Would this work ? It's probably 70's-early 80's .   https://www.ebay.com/itm/Westinghouse-Lifeguard-H38MP-100-DX-100W-Mercury-Vapor-Light-Bulb-Lamp-USA/161402597112
Bulbman256
Mad Max
Bulbman256
Re: H38 ballast and bulb wanted « Reply #7 on: June 30, 2020, 04:58:45 PM » Author: Bulbman256
I ordered my ballast today and when if it arrives safe i will go ahead and order the lamp i descibed above an an ed shaped ge 100w clear mogul lamp from the 80s :)
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: H38 ballast and bulb wanted « Reply #8 on: September 19, 2020, 06:36:12 PM » Author: HPS_250
I got one of these last month, it’s from 1976. Very good quality H38 mercury lamp, and I’d recommend it if you want a lifeguard.
