Author Topic: Iwasaki Eye 150W HPS Lamp  (Read 3046 times)
Iwasaki Eye 150W HPS Lamp « on: June 13, 2020, 07:59:13 AM » Author: sox35
Saw this and I'm rather tempted, but the arc tube looks very small for a 150W lamp ???
(Admin edit - Listing has ended but info can still be seen)
« Last Edit: October 10, 2020, 01:47:42 PM by Lightingguy1994 » Logged
Xytrell
Re: Iwasaki Eye 150W HPS Lamp « Reply #1 on: June 13, 2020, 10:31:31 AM » Author: Xytrell
...the arc tube looks very small for a 150W lamp ???
I thought so, too, but then I saw it was an E40 base and the scale makes more sense.
Re: Iwasaki Eye 150W HPS Lamp « Reply #2 on: June 13, 2020, 10:42:33 AM » Author: sox35
I don't think so, there are plenty of 150W lamps with E40 caps, and the arc tubes are larger than this one, see here for an example.
Re: Iwasaki Eye 150W HPS Lamp « Reply #3 on: June 13, 2020, 11:58:13 AM » Author: Lumex120
That's a rare white HPS lamp. They have a color similar to an incandescent lamp but are a little less efficient and don't last as long.
Unofficial LG Discord
WestinghouseCeramalux
Re: Iwasaki Eye 150W HPS Lamp « Reply #4 on: June 13, 2020, 12:04:45 PM » Author: WestinghouseCeramalux
Worth getting then, at that price. It's not going to be run into the ground to EOL in the collection, so I think it's a good lamp to have  :son-t:
Re: Iwasaki Eye 150W HPS Lamp « Reply #5 on: June 18, 2020, 01:35:42 PM » Author: sox35
This is a Specialux lamp...definitely worth getting.
Re: Iwasaki Eye 150W HPS Lamp « Reply #6 on: June 18, 2020, 02:50:20 PM » Author: WestinghouseCeramalux
It's due for delivery by the courier sometime in the next hour  :bulbman:
Re: Iwasaki Eye 150W HPS Lamp « Reply #7 on: June 18, 2020, 03:26:25 PM » Author: Mandolin Girl
8)
Re: Iwasaki Eye 150W HPS Lamp « Reply #8 on: June 18, 2020, 05:35:37 PM » Author: sox35
It arrived about half past eight, delivered by our usual Hermes courier, and we had a nice chat with him.  :bulbman:
Re: Iwasaki Eye 150W HPS Lamp « Reply #9 on: June 18, 2020, 05:37:19 PM » Author: WestinghouseCeramalux
We're just wondering if it needs special gear to run, as we don't want to blow it up on its first ever lighting  :o :poof:
Re: Iwasaki Eye 150W HPS Lamp « Reply #10 on: June 18, 2020, 07:53:16 PM » Author: WestinghouseCeramalux
Can't speak for UK gear, but I can run mine on standard US gear without and problem. Maybe James can fill you in on the specs.
« Last Edit: June 18, 2020, 08:12:42 PM by WestinghouseCeramalux » Logged
Re: Iwasaki Eye 150W HPS Lamp « Reply #11 on: June 18, 2020, 08:11:37 PM » Author: wide-lite 1000
Congratulations on your new "bundle of joy"  :hps:
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Iwasaki Eye 150W HPS Lamp « Reply #12 on: June 18, 2020, 08:45:10 PM » Author: Binarix128
Seems like the arctube is more pressurised than normal 150w HPS arctubes. If the lamp is 150wm It should thake the 150w from the gear, the only difference is that the lamp run with more pressure.
I'm not a 100% about that, but that can be the case. But please don't plug it into a 150w HPS setup and blow up anything by a newbie member.  :o
Re: Iwasaki Eye 150W HPS Lamp « Reply #13 on: June 18, 2020, 09:17:39 PM » Author: sox35
Yes, it runs at higher pressure...this is typical for a DX lamp.
Re: Iwasaki Eye 150W HPS Lamp « Reply #14 on: June 19, 2020, 08:43:52 AM » Author: sox35
Sadly, I think this lamp is going to have to remain unlit for the moment, the last thing I want to do is blow it up  :'( :sadbulb:
