Author Topic: How to make a florescent tube light reach eol  (Read 18705 times)
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: How to make a florescent tube light reach eol « Reply #15 on: June 10, 2020, 01:50:59 PM » Author: Binarix128
Making a tuve starve will take its time.
Tiny cracks microscopic cracks should appear if produce a thermic shock in the tube, but sufficent to make air get in or mercury can get out.
LucasColley
Re: How to make a florescent tube light reach eol « Reply #16 on: June 10, 2020, 01:56:24 PM » Author: LucasColley
Ok I’ll try that eventually. Could you give me the link of a Phillips alto bulb if you have one.
LucasColley
Re: How to make a florescent tube light reach eol « Reply #17 on: June 10, 2020, 01:59:50 PM » Author: LucasColley
Ok I’m trying to apply 12v dc to the bulb like some people recommend that’s the best thing you can do to eol the bulb, so how do I wire it up? Do I apply the striped wires to the ballast? Or do I apply the striped wires to the pins and plug it  in?
Re: How to make a florescent tube light reach eol « Reply #18 on: June 10, 2020, 02:27:48 PM » Author: xmaslightguy
Apply the  12v directly to the pins of the lamp, no ballast needed
Also here's one example of a standard Alto.
http://lighting-gallery.net/gallery/displayimage.php?pos=-43859
I've had one of those ^ go mercury-starved (outside on a electronic RS ballast .. in winter, it was too cold to make it light)
Also had another type go mercury-starved .. the one mentioned with a bad ballast (which surprisingly I never uploaded a pic (I'll have to rectify that situation!))
LucasColley
Re: How to make a florescent tube light reach eol « Reply #19 on: June 10, 2020, 02:34:15 PM » Author: LucasColley
Ok to wire it does it matter what cord I use when I strip it? I’m new with dc I’m not sure if it’s hot or neutral. Or it just doesn't matter.
Re: How to make a florescent tube light reach eol « Reply #20 on: June 10, 2020, 02:38:38 PM » Author: xmaslightguy
In this case it doesn't matter since its just a filament (you could even technically use 12v AC)
If you were lighting LEDs, or running electronics, that's where it'd be important to get the + & - connected correctly.
LucasColley
Re: How to make a florescent tube light reach eol « Reply #21 on: June 10, 2020, 02:43:42 PM » Author: LucasColley
Ok got it and one more thing when I apply the wires to the pins of the lamp do I split the wire to touch both pins on each side of the tube? Or just put one wire on each pin on each side of the tube?
Re: How to make a florescent tube light reach eol « Reply #22 on: June 10, 2020, 03:08:13 PM » Author: xmaslightguy
You'll want to do both pins.
Try first doing it so they're in series - one output wire from the 12v to a pin on each end, then connect the other 2 pins with a wire along the lamp (this'll give 6v per filament which might not be enough, but its a good starting point)...
If you don't see any glow in the ends, then change it so both wires go to both pins on each end so they get the full 12v.
Also if you have a way to flash it - turn on/off a couple times per minute, that should work quite well/speed things up..
LucasColley
Re: How to make a florescent tube light reach eol « Reply #23 on: June 10, 2020, 03:38:18 PM » Author: LucasColley
So I split the wire onto both pins on each side of the tube? I’m just making sure lol sorry.
LucasColley
Re: How to make a florescent tube light reach eol « Reply #24 on: June 10, 2020, 03:52:51 PM » Author: LucasColley
And how do I know which wire I apply to the pin? Does it matter?
Re: How to make a florescent tube light reach eol « Reply #25 on: June 10, 2020, 03:55:48 PM » Author: xmaslightguy
Yep, that's it.
Doesn't matter which wire goes to which pin.
Re: How to make a florescent tube light reach eol « Reply #26 on: June 10, 2020, 03:57:20 PM » Author: Ash
Would anyone explain how blowing a cathode would make the lamp mercury starved ?
LucasColley
Re: How to make a florescent tube light reach eol « Reply #27 on: June 10, 2020, 05:15:29 PM » Author: LucasColley
How would I wire that up? Just to the pins right? If so I just don’t know what wires to use
Put them on the incorrect gear such as a 400w HPS ballast. As for making them pink, I don't know.
Re: How to make a florescent tube light reach eol « Reply #28 on: June 10, 2020, 05:39:05 PM » Author: xmaslightguy
@Ash:
The idea is actually not   to blow the cathode, just heat it up. (ideally heat..cool..heat..cool... particularly if you can intermittently light the tube. I don't know why that makes them go mercury starved, but it does.)
LucasColley
Re: How to make a florescent tube light reach eol « Reply #29 on: June 11, 2020, 01:59:49 AM » Author: LucasColley
So I added the dc voltage to it and it was pretty cool, didn’t want to burn it out completely but now that it has a burn mark on the end like a used tube light, will it die shorter? Or last the same amount of time?
