Author Topic: What do you use as a nightlight  (Read 16231 times)
Re: What do you use as nightight « Reply #15 on: June 09, 2020, 01:27:56 AM » Author: tolivac
I sleep during the day-so what sun gets in thru the blackout shades could be my "nightlight" I get up at 10:00PM for work-then the light leakage from the UV bulb in my air purifier acts as a "nightlight".
Re: What do you use as nightight « Reply #16 on: June 09, 2020, 06:11:07 AM » Author: HomeBrewLamps
1000 watt hps.
~Owen
Bulbman256
Mad Max
Bulbman256
Re: What do you use as nightight « Reply #17 on: June 09, 2020, 09:21:31 AM » Author: Bulbman256
1000 watt hps.
Do you sleep with a blindfold on or do you go blind while you sleep?  ::) :lol:
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: What do you use as nightight « Reply #18 on: June 09, 2020, 02:10:41 PM » Author: Binarix128
1000 watt hps.
I think you mean the fixture that you see from the window.  :lol:
Seems like per every 1kw session, the next day you will need to twice the power.  :lol:
Xytrell
Re: What do you use as nightight « Reply #19 on: June 10, 2020, 02:23:46 AM » Author: Xytrell
I use a selenite tower lit below by a few red LED stars mounted on an old heat sink and powered by an old plug pack. Love the sinister ominous glow.
Metal Halide Boy
Re: What do you use as nightight « Reply #20 on: June 12, 2020, 12:03:33 PM » Author: Metal Halide Boy
A 7w? incandescant bulb, or a battery powered LED lantern.
Bulbman256
Mad Max
Bulbman256
Re: What do you use as nightight « Reply #21 on: June 12, 2020, 06:21:23 PM » Author: Bulbman256
I use some ge 4 watt blue night light lamps in a normal on off switch night light. The blue is dimmer that clear, soft white, and pink but the shoterwavelengs may cause me to not sleep well idk i may change it out for something else once im done moving.I  cant sleep with too much light or no light and also need light to not fall during andy bathroom trips. Might consider using a flicker flame or some neon lamps once i get some.
Re: What do you use as nightight « Reply #22 on: June 12, 2020, 06:28:02 PM » Author: sol
You could also try some red Christmas C7. That’s what I use and they offer the best compromise between sleeping and safety.
HPSM250R2
Re: What do you use as nightight « Reply #23 on: June 12, 2020, 10:28:26 PM » Author: HPSM250R2
Isn't it not safe for you to be around that air purifier if UV light is leaking out of it?
Re: What do you use as nightight « Reply #24 on: June 12, 2020, 10:54:05 PM » Author: Lumex120
I use a white neon bulb that I attached to a candelabra base from a broken C7 lamp installed in an automatic night light. It isn't very bright but at night it's really effective for seeing around. It looks like a tiny /DX mercury bulb.
Unofficial LG Discord
Bulbman256
Mad Max
Bulbman256
Re: What do you use as nightight « Reply #25 on: June 20, 2020, 06:31:13 PM » Author: Bulbman256
Ok, will try one i'm done moving as i have some 7 watt c7 red bulbs that i can use.
Xytrell
Re: What do you use as nightight « Reply #26 on: June 21, 2020, 02:24:13 AM » Author: Xytrell
The "leaking" is likely the visible parts bouncing around corners of the enclosure. UV doesn't do as much bouncing as it is absorbed or attenuated by many materials. Even if it weren't, I'd imagine the inverse square law puts your dosage lower than that of being outside.
RadxD461
Re: What do you use as nightight « Reply #27 on: June 21, 2020, 09:19:29 PM » Author: RadxD461
What kind of nightlight do you use? Incandescent, fluorescent, neon, LED?
I prefer incandescents, spetially halogen since some incandescents hums at low levels of the dimmer.
I like incandescent since is the most similar to a candle, with a smooth CRI and a low level of blue light, wich helps a little to sleep. Fluorescent ones are a bit spiky in spectrum to my taste, and LED emmites huge amounts of blue light wich affects the sleep and can even be harmful. Red LED can be ok, but I don't like the effect much.
I use my a thousand watt metal halide light bulb ;D ;D ;D ;D ;D
Binarix128
220V AC 50Hz, NTSC
Re: What do you use as nightight « Reply #28 on: June 21, 2020, 09:23:33 PM » Author: Binarix128
R U joking. Right?  ;D :lol: ::)
RadxD461
Re: What do you use as nightight « Reply #29 on: June 21, 2020, 09:30:10 PM » Author: RadxD461
yes I am completely joking. ;D ;D ;D ;D ;D ;D I use a 23 watt incandescent light bulb for a night light.
