Author Topic: Guess what  (Read 2924 times)
RadxD461
Guess what « on: May 23, 2020, 08:27:53 PM » Author: RadxD461
Guess what guys, I have just purchased a Philips 175 watt clear mercury vapor lamp from 1996!
Okay guys I miss typed :sadbulb:  the bulb is actually from 1996.
« Last Edit: May 24, 2020, 08:23:04 PM by HPSMVF » Logged
Patrick
Webmaster
LightingGallery
Re: Guess what « Reply #1 on: May 23, 2020, 09:36:50 PM » Author: Patrick
If it's an American lamp, it can't both be Philips and from 1963.  Due to Philco's trademark, Philips was unable to use their own name in the United States prior to 1981, which was the reason they original operated here under Norelco.
Patrick C., Administrator
RadxD461
Re: Guess what « Reply #2 on: May 23, 2020, 09:48:00 PM » Author: RadxD461
it is an American-made lamp! And it says Phillips on the package.
Patrick
Webmaster
LightingGallery
Re: Guess what « Reply #3 on: May 23, 2020, 09:54:15 PM » Author: Patrick
It'd think it'd have to be made after 1985 or 1986.  Prior to that it'd be Norelco, Westinghouse, or Philips-Westinghouse.
Re: Guess what « Reply #4 on: May 24, 2020, 01:30:27 AM » Author: wide-lite 1000
If it's american made then it must be newer. https://www.lighting-gallery.net/gallery/displayimage.php?album=5200&pos=74&pid=158120
RadxD461
Re: Guess what « Reply #5 on: May 24, 2020, 09:29:23 AM » Author: RadxD461
weird, it says September of 1963.
RadxD461
Re: Guess what « Reply #6 on: May 24, 2020, 09:30:55 AM » Author: RadxD461
What's the date code (for example: A3, 6F, G4, etc.)?
I do not have the actual lamp yet. It is on its way to my house.
Re: Guess what « Reply #7 on: May 24, 2020, 04:39:07 PM » Author: Ash
Made for export ? (To some other country that uses NEMA lamp types - So most likely 120V/60Hz country)
Re: Guess what « Reply #8 on: May 24, 2020, 05:11:45 PM » Author: sox35
I'll be interested in seeing a picture once you get it  :bulbman:
RadxD461
Re: Guess what « Reply #9 on: May 24, 2020, 06:22:09 PM » Author: RadxD461
yes I'm very excited! I should get it next week.
RadxD461
Re: Guess what « Reply #10 on: May 24, 2020, 08:24:05 PM » Author: RadxD461
Patrick
Webmaster
LightingGallery
Re: Guess what « Reply #11 on: May 24, 2020, 11:05:06 PM » Author: Patrick
Ah, that'd explain it.  I'm not sure if Philips was still using the Westinghouse Lifeguard arc tubes at that point.  Nevertheless, it should be a decent lamp.
