Author Topic: CFL Quality  (Read 4178 times)
Metal Halide Boy
CFL Quality « on: May 18, 2020, 04:16:41 PM » Author: Metal Halide Boy
I found these on Ebay. Are they very well made?
https://www.ebay.com/itm/6ea-NEW-PHILIPS-146910-LIGHT-BULB-SLS-14W-TRIPLE-TUBE-SCREW-BASE-CFL-Soft-White/303279521303?epid=3012086656&hash=item469cde3e17:g:xvwAAOSw6eRddqBJ
fluorescent lover 40
Re: CFL Quality « Reply #1 on: May 18, 2020, 04:35:19 PM » Author: fluorescent lover 40
Yes, these were some of the best CFLs Philips made.
Metal Halide Boy
Re: CFL Quality « Reply #2 on: May 19, 2020, 08:12:10 AM » Author: Metal Halide Boy
OK, I`ll probably get some.
Meme Pods
A nice daylight CFL
UCKBWkfqE5WPMlFZmssITqPQ
Re: CFL Quality « Reply #3 on: June 13, 2020, 10:10:44 PM » Author: Meme Pods
Yes these are good quality
Down with the halogen bulbs
Re: CFL Quality « Reply #4 on: June 14, 2020, 01:02:29 AM » Author: Medved
But the question is, whether mainly the electrolytic capacitor survive the power up after all those years of sitting (it may need reforming but that is impossible without disassembling the thing first)...
High Intensity
Re: CFL Quality « Reply #5 on: June 14, 2020, 01:06:10 AM » Author: High Intensity
From my experience, the electrolytic capacitors in older CFLs are a lot more robust than they're given credit for, as i've never had one suddenly fail in a NOS lamp.
Re: CFL Quality « Reply #6 on: June 14, 2020, 04:10:23 PM » Author: Ash
What if not using a resistor as the current limit, but only ramp up DC voltage slowly with a low impedance DC source ? The lamp starting won't affect the capacitor voltage in this case, so it won't start flashing with the capacitor voltage oscillating. Could powering it with DC undervoltage damage the rest of the ballast ?
Re: CFL Quality « Reply #7 on: June 15, 2020, 03:35:20 PM » Author: Medved
Undervoltage may damage the lamp - operating it for quite some time with cold cathodes will sputter them quickly.
Silverliner
Rare white reflector
Re: CFL Quality « Reply #8 on: June 17, 2020, 04:19:52 AM » Author: Silverliner
I lit up an NOS Norelco SL*18 lamp made in 1983. Lit with no problems whatsover.
Member of L-G since 2005.
Electrician.
Re: CFL Quality « Reply #9 on: June 17, 2020, 07:59:55 AM » Author: Medved
But isn't that using series reactor ballast and a preheat circuit? Then there is no component to degrade by storage...
Metal Halide Boy
Re: CFL Quality « Reply #10 on: June 17, 2020, 12:41:42 PM » Author: Metal Halide Boy
I got some and they work fine.
Re: CFL Quality « Reply #11 on: June 17, 2020, 12:53:59 PM » Author: Ash
Would it even strike at voltages low enough to be a problem ? (when ramping up, not letting it start at higher voltage and going down)
Re: CFL Quality « Reply #12 on: June 17, 2020, 11:17:55 PM » Author: Medved
The resonance boost up the voltage. It clearly ignites the discharge when the voltage just reaches the diac breakover (see the ghost flashing common with the 2way switch arrangements) - so about 40V is enough to ignite it even with cold electrodes.
Re: CFL Quality « Reply #13 on: June 18, 2020, 05:44:42 PM » Author: Ash
But is the applied votlage sufficeint to strike the discharge ? For all i know it might just be running at above resonance, heating the cathodes continuously, but unable to do anything else...
And what if the capacitor forming is "skipped" from below lamp striking voltage to voltage at which the cathodes are just about warm enough to not sputter - Assuming it is still far from full rectified line voltage, would it still be acceptable for forming the capacitor ?
Re: CFL Quality « Reply #14 on: June 19, 2020, 01:10:43 AM » Author: Medved
The flashing CFLs on many two way ciruits is a good proof, I think, the 40V is enough to ignite the discharge. Just the capacitor charge purged into the inverter once per minute is in no way capable to heat up the electrodes, yet CFLs are flashing there.
Of course it depends on the exact design, but mainly the first electronic models had nothing to prevent the cold ignition.
