Author Topic: LED Replacement Fluorescent Tube Fire/Failure  (Read 3497 times)
Mr. Orthosilicate
LED Replacement Fluorescent Tube Fire/Failure « on: May 05, 2020, 10:13:54 PM » Author: Mr. Orthosilicate
While the procedure seems suspect, considering he continued to rotate the lamp further to cause more arcing, it was fun to watch.
https://m.youtube.com/watch?v=mCvnG0uukAY
Re: LED Replacement Fluorescent Tube Fire/Failure « Reply #1 on: May 06, 2020, 02:00:51 AM » Author: Medved
Normally there is nothing preventing such movement when e.g. vibrations or thermal cycles (as the arc starts and stops) are present, it would just take longer.
The rotation was just simulating the possible worst case scenario. it is how safety tests are supposed to be done - actively search for and identify weak points. Then measures could be designed to make it safe, but that is then a follow up thing.
