Author Topic: T5 Flourescent Lamps  (Read 3808 times)
T5 Flourescent Lamps « on: January 31, 2009, 02:23:00 PM » Author: dor123
What is The Differences Between the vintage T5 Mini Fluorescent lamps <13W & the modern HO & HE Long T5 Flourescent lamp >14W
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: T5 Flourescent Lamps « Reply #1 on: January 31, 2009, 07:13:03 PM » Author: Foxtronix
By the way welcome to Lighting-Gallery!
The HO (high output) lamps are fluorescent lamps with an higher lumen output per inch. For example an F40T12/CW is 4 foot long and consumes 40W. An F48T12/CW/HO is 4 foot long as well, but consumes 60W. They exist in T12, T10 (not sure), T8, T6 and T5 sizes.
Re: T5 Flourescent Lamps « Reply #2 on: January 31, 2009, 07:25:48 PM » Author: dor123
The T5 HO is a T5 fluorescent lamps that are very long, with wattage higher then 24W, its brightness is the highest of all types of fluorescent lamps, almost as bright as compact fluorescent lamps, it can be run ONLY by electronic ballasts and if you run this lamp with Preheat Start ballast it will achieve an average life of 24,000 hours and a service life of 18,000 hours. also this avarage efficiency is as high as 100 Lm/W.
« Last Edit: January 31, 2009, 07:41:03 PM by dor123 » Logged
Foxtronix
Re: T5 Flourescent Lamps « Reply #3 on: January 31, 2009, 08:14:30 PM » Author: Foxtronix
Well many manufacturers make the high output T5s, so the lamps of each brands have his compatible ballasts. Which brand are you talking about?
Re: T5 Flourescent Lamps « Reply #4 on: January 31, 2009, 08:21:53 PM » Author: dor123
I talking about all brands. but I don't know why T5 HO & HE are Much more bright & efficient then the old short T5. perhaps because they contain another buffer gas then the short T5.
Foxtronix
Re: T5 Flourescent Lamps « Reply #5 on: January 31, 2009, 09:01:57 PM » Author: Foxtronix
That's because they run at an higher current (explains also the higher wattage than normal tubes of the same length).
Re: T5 Flourescent Lamps « Reply #6 on: February 01, 2009, 11:20:13 AM » Author: dor123
which buffer gas there is in the T5 HO & HE fluorescent tubes?
Foxtronix
Re: T5 Flourescent Lamps « Reply #7 on: February 01, 2009, 11:39:56 AM » Author: Foxtronix
Generally the same as all other fluorescents, argon to be exact.
Re: T5 Flourescent Lamps « Reply #8 on: February 01, 2009, 01:01:20 PM » Author: dor123
This means that compact fluorescent lamps also contains argon only as a buffer gas and run at higher current because both CFL and T5 HO are very bright.
Foxtronix
Re: T5 Flourescent Lamps « Reply #9 on: February 01, 2009, 01:20:12 PM » Author: Foxtronix
Actually the T5s and CFLs are very small tubes, 5/8 inch for the T5s and as small as 2/8 inch for certain CFLs, so the phosphor is closer to the arc and brighter.
Re: T5 Flourescent Lamps « Reply #10 on: March 24, 2009, 04:24:48 PM » Author: Medved
Because of less volume, it takes shorter path for an UV photon from the excited mercury atom to the phosphor before it's absorbed back by some unexcited atom. This was known since the fluorescent lamp birth, as well was an associated  significant consequence: Higher operating wall temperature, while this was an two-fold obstacle:
1) Phosphors tend to loose their efficiency on high temperature.
2) Mercury vapor pressure too high, causing higher selfabsorbtion.
So lamps were designed for most optimal current density (so diameter) and consequently dimension standard was set
The first one was overcome by new chemistry used today, the second by the use of amalgams as mercury reservoirs, so the pressure is less dependent on temperature.
Taking these adoptions into account, "old standard" sizes are not anymore lying on the optimum for given wattage rating, so adopted combinations, generally marked as "HO", were standardized, usually reducing tube diameter by one step, so e.g. ~4foot long 36W does not use T8, but T5 tube instead, becoming F36T5HO lamp.
Alights
USA (120V 60HZ)
Re: T5 Flourescent Lamps « Reply #11 on: July 08, 2009, 06:59:14 PM » Author: Alights
you can combine different ballasts brands with different branded lamps just like any other. I have a 28W t5 4 foot strip that is 2 lamp,and it is rapid start with EOL cut. anyways, I like to try new lighting technology as well as the old.
don93s
Re: T5 Flourescent Lamps « Reply #12 on: August 16, 2009, 01:52:32 PM » Author: don93s
Also, the newer phosphor technology makes the higher current T5 possible.
