Author Topic: How are these brackets removed?  (Read 2612 times)
LampLover
120/240VAC @ 60HZ
How are these brackets removed? « on: April 22, 2020, 08:36:30 PM » Author: LampLover
I have these two lamps with similar looking brackets. I have this Luxo that has a rolling floor stand and this Chinese clone with a table clamp bracket the way they attach to their respective mount looks the same and I would like to have the Luxo lamp on the clamp mounted near me at my desk as I use that more for small projects the other lamp will probably be put in storage as I don't use it that much, if at all. I just want to know how (if at all possible) to remove it. I think it can in-fact be done as I have seen lamps for sale on eBay and other sites that have just the metal rod that attaches to a bracket and no actual mount included. I just want to know if there is a certain right way to remove it.
Thanks
LED Free Zone!
Re: How are these brackets removed? « Reply #1 on: April 22, 2020, 09:25:59 PM » Author: sol
Some portable swing arm lamps (as opposed to clamp-on-desk ones) have a set screw that holds it in the hole and also limits the swing so it does not topple over. Look carefully as said set screw is most likely hidden, recessed, painted to match the base or all of the above. I know mine do, however none are Luxo.
LampLover
120/240VAC @ 60HZ
Re: How are these brackets removed? « Reply #2 on: April 22, 2020, 09:33:20 PM » Author: LampLover
Where on the fixture base would such set screw be located?
LED Free Zone!
Re: How are these brackets removed? « Reply #3 on: April 22, 2020, 09:39:18 PM » Author: sol
On the base, in alignment with the hole into which the swivel part goes.
Re: How are these brackets removed? « Reply #4 on: April 22, 2020, 09:40:40 PM » Author: sol
Immediately below the ballast box of your Circline lamp, there is a fat swivel pin that goes into the stand. The setscrew would be on the stand, protruding into the hole into which the swivel pin goes.
Re: How are these brackets removed? « Reply #5 on: April 22, 2020, 09:48:57 PM » Author: sol
See the part I circled in red on this picture from overstock.com.
LampLover
120/240VAC @ 60HZ
Re: How are these brackets removed? « Reply #6 on: April 23, 2020, 12:00:40 PM » Author: LampLover
OK thanks I will look at them more closely latter.
LED Free Zone!
