Author Topic: Advice about chossing a ballast for a project :mv:  (Read 2263 times)
Bulbman256
Mad Max
Bulbman256
Advice about chossing a ballast for a project :mv: « on: April 08, 2020, 10:06:58 PM » Author: Bulbman256
Hello people of LG. I am asking about choosing a ballast for a project of mine. I was wondering if i could use a 100w psmh ballast to run a 100w mv (with the igniter removed from the circuit). I am asking this as i can nor find a h38 ballast new anywhere online and was curious if a metal hailed substitute would work. The whole point of this is to try and get my self equated with HID lighting and to (maybe) power up my old ken-rad 100w floods if i find an admedium socket. Also i may use it as a remote or Incorporated ballast for a project in the future. Thanks in advance for any info.  :mv:
Re: Advice about chossing a ballast for a project :mv: « Reply #1 on: April 08, 2020, 10:52:53 PM » Author: joseph_125
IIRC a 100w PSMH ballast will run a MV lamp at around 110-120w which will overdrive a H38 lamp. I usually run the more common in Europe 125w mercury lamps on them. A 70w PSMH ballast will be the closest to a running a 100w mercury to the correct spec. I use 70w PSMH all the time to run 100w mercury lamps mainly since the correct 100w H38 is hard to find outside of eBay.
Bulbman256
Mad Max
Bulbman256
Re: Advice about chossing a ballast for a project :mv: « Reply #2 on: April 09, 2020, 09:34:09 AM » Author: Bulbman256
Thank you man! This info will work great for my project. Thank you for your cooperation. :mv: :bulbman:
Bulbman256
Mad Max
Bulbman256
Re: Advice about chossing a ballast for a project :mv: « Reply #3 on: April 09, 2020, 11:04:48 AM » Author: Bulbman256
found a H38 on ebay that is 120v and not any other voltage but can t do the project right now until about late june but if anyone wants a link here is one: https://www.ebay.com/itm/Advance-Transformer-Co-120V-For-100Watt-H38-Lamp/114176802576?hash=item1a9577bf10:g:MmwAAOSweNVejKbr
Re: Advice about chossing a ballast for a project :mv: « Reply #4 on: April 09, 2020, 11:58:35 AM » Author: Lumex120
Ok that's really strange! I'm thinking it's probably homemade or something but for what I don't know. By the way, if when you get back to this project and can't find a ballast, I have a bunch of extra 70w metal halide ballasts and I could part with one or two.
Unofficial LG Discord
Bulbman256
Mad Max
Bulbman256
Re: Advice about chossing a ballast for a project :mv: « Reply #5 on: April 09, 2020, 12:31:58 PM » Author: Bulbman256
Thanks for the offer, my family is in the process of moving and will be done in mid june ish depending on how corona turns out so i cant buy any new parts until then and when i move they will finally let me get some florescent fixtures adn other lighting stuff so i am exsided for that, i think that this  a small conversion kit to turn a lamp into a remote ballast lamp with one of those philips a23 100w bulbs.
