Author Topic: LEP grow lamp?  (Read 2705 times)
marcopete87
LEP grow lamp? « on: March 27, 2020, 05:42:15 PM » Author: marcopete87
Hi all, anyone have some info on light emitting plasma?  :poof:
As far as i remember, there are a bunch of sulfur lamp and nothing else...
This is an interesting technology.
https://translate.google.com/translate?sl=it&tl=en&u=https%3A%2F%2Fwww.idroponica.it%2Fgavita-pro-270e-lep~25626.html
Re: LEP grow lamp? « Reply #1 on: March 27, 2020, 07:39:45 PM » Author: Mandolin Girl
No heat output.!!  :poof: The cops are going to love those... :curse:
Finding the houses that glow brightly under IR is the main way they find the grow houses.
Re: LEP grow lamp? « Reply #2 on: March 28, 2020, 01:09:30 AM » Author: tolivac
The LEP lamps DO produce heat-but not as much.Their TINY bulbs get VERY hot and are under higher pressure than other HID bulbs.The ballasts generate some heat and LTS of RFI,EMI.Electronic ballasts are easierto track than magnetic ones because of the RFI and EMI radiations.And the LEP lamps put out larger amounts of UV-users of these lamps are warned about it-UVB.Stay in the grow room with these lamps--you could get a sunburn or burned eyes.The LEP lamp makers suggest door switches to the grow areas to turn those lights off if the door to the room is opened.And outside switches to turn them off.These grow lamps are also VERY EXPENSIVE-Almost 800-1000$ per fixture.The bulbs aren't user replaceable.You have to send the fixture back to Gavita or other maker to have the light relamped.
Re: LEP grow lamp? « Reply #3 on: March 28, 2020, 02:19:02 AM » Author: dor123
Light Emitting Plasma = Electrodeless MH lamp, and it produces the same amount of heat and IR as electroded MH lamps.
lights*plus
George Liv Photo
Re: LEP grow lamp? « Reply #4 on: April 12, 2020, 03:05:42 PM » Author: lights*plus
Threads with loads of info...
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-127815
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-126126
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-152221
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-126123
BlueHalide
Re: LEP grow lamp? « Reply #5 on: April 12, 2020, 05:51:47 PM » Author: BlueHalide
I have seen these LEP systems in person a few years back at a horticulture trade show (my wife likes gardening).
They are in fact electrodeless metal halide, with the power inductively coupled to the capsule similarly to induction fluorescent. When switched on they power up quite similarly to a daylight MH lamp.
And regarding the heat, its a bit misleading. A 250w LEP fixture is more efficient than quartz metal halide and therefore emits less heat than the 400w lamp it replaces, but it still produces loads of heat for its power, well, roughly the same heat as a 250w standard MH lamp while emitting the same lumen output as a 400w. The fixture I saw running in person was definitely throwing off some heat.
