Author Topic: Strange Warning On Regent Mercury Vapor Lamp.  (Read 4108 times)
form109
Strange Warning On Regent Mercury Vapor Lamp. « on: January 23, 2009, 11:42:36 PM » Author: form109
i was reading the instructions,that came with my Regent 175 Watt Clear Merc,and i noticed it said the lamp contains Mercury and Sodium...i got the Mercury part...but Sodium?..why would a Mercury Vapor Lamp have Sodium in it,can somebody help me out. ???
Silverliner
Rare white reflector
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #1 on: January 24, 2009, 02:17:27 AM » Author: Silverliner
That's just an error, be assured NO mercury vapot lamps contain mercury :-)
By the way another similar error I have seen is that the Feit HPS lamps made in China have the R symbol. This symbol is only required on HID lamps that emit UV and don't fail after lamp breakage, which are MV and MH. Special ones that go out after glass breakage have the T symbol. So it's weird seeing the R on a HPS lamp!
Member of L-G since 2005.
Electrician.
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #2 on: January 24, 2009, 11:26:34 AM » Author: icefoglights
Sounds like either a printing error or they just use the same warning sheet with both HPS and MV lamps.
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #3 on: January 25, 2009, 10:50:10 AM » Author: Foxtronix
Form 109, I have the same error on my Caster lamp package. I thought at first it was a translation error (I read the french instructions first, that's too funny to read....), but the error gets repeated in english.
gmercury2000
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #4 on: January 25, 2009, 01:17:21 PM » Author: gmercury2000
Ok so are HPS lamps dangerous when broken, Minus fire hazard? I have always wonderd that but I never see UV warnings. Just curious!
form109
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #5 on: January 25, 2009, 01:36:21 PM » Author: form109
i've opperated a Busted HPS Lamp,i could smell a Hint of Ozone,so it probably does produce a little UV.
lightman64
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #6 on: January 25, 2009, 03:11:41 PM » Author: lightman64
i had a Phillips MV lamp that was 175 watt and it said on the box to use it only in a H37 ballast which i think is 250 watt. it seems to work fine on a H39 and the bulb says 175....
gmercury2000
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #7 on: January 25, 2009, 03:54:42 PM » Author: gmercury2000
I had one of those, it was a Philips brand. I dont have the box anymore but it said the same thing. The lamp it's self said H39. If it's a 175 watt merc, it is H39. Just a typo.
Foxtronix
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #8 on: February 02, 2009, 08:11:00 AM » Author: Foxtronix
In this case putting an H39 lamp on H37 ballast can cause the lamp to explode, especially with a chinese lamp.
lightman64
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #9 on: February 02, 2009, 04:18:31 PM » Author: lightman64
what about the other way?
form109
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #10 on: February 02, 2009, 05:20:10 PM » Author: form109
is H-37 the ballast code for 250 watts?
lightman64
Re: Strange Warning On Regent Mercury Vapor Lamp. « Reply #11 on: February 03, 2009, 06:46:42 PM » Author: lightman64
yes it is.
