Author Topic: How do 3-Way CFLs Work?  (Read 6075 times)
lightman64
How do 3-Way CFLs Work? « on: January 19, 2009, 11:55:25 AM » Author: lightman64
how does a 3-way cfl work? i have one and is very different.
« Last Edit: January 19, 2009, 05:23:21 PM by lightman64 » Logged
hotrestrike
Re: How do 3-Way CFLs Work? « Reply #1 on: January 22, 2009, 11:38:49 PM » Author: hotrestrike
Most of them have internal fixed-type dimming circuitry - they just operate the tube at a lower power settings depending on which socket contact is energized (that is, the first & second clicks on a 3-way lamp switch) and full power when both contacts are energized (3rd click).
Some actually use two tubes of two different wattages....like the circline 3-way types.
lightman64
Re: How do 3-Way CFLs Work? « Reply #2 on: January 23, 2009, 05:46:58 PM » Author: lightman64
thats really cool! i always wondered how they worked.
Parrot
YouTube: Parrot175
Parrot175 parrot175
Re: How do 3-Way CFLs Work? « Reply #3 on: January 12, 2010, 08:52:23 PM » Author: Parrot
I always wondered how they worked too. Cool to know. I had some they only lasted about 9 months not what it seed on the package.
Re: How do 3-Way CFLs Work? « Reply #4 on: January 13, 2010, 02:08:15 PM » Author: Medved
Very frequently the dimming (mainly the lowest level) is implemented in very crude way (switching from doubler to bridge rectifier configuration, so lowering the DC voltage for the inverter), so it doesn't maintain correct electrode temperature when dimmed, so they sputter away very quickly...
DieselNut
John
Re: How do 3-Way CFLs Work? « Reply #5 on: February 06, 2010, 11:11:26 PM » Author: DieselNut
I would love to find a circline like you mentioned.  The type with two lamps of different wattages.  I have a HUGE table lamp that originally had a 100, 200, 300 3-way incandescent in it.  I now just have a 22 watt circline in it.  Would love an "old school" (preheat) 3 way.  I have even thought about building one if I cannot find one!
Preheat Fluorescents forever!
Re: How do 3-Way CFLs Work? « Reply #6 on: February 07, 2010, 01:29:46 AM » Author: Medved
I would be thinking about making one by yourselve:
It would be for FC6T9 and FC8T9, as nothing else then serial choke would not fit (and higher wattages need a HX transformer), or you would have to go electronic
Find a can, that would just fit inside the FC6
Find ballasts for these lamps
Find fired 3-way CFL, cut the bottom part with the socket of the ballast box
Make 2..3 holes into it and bolt it to the ballast can
Put two ballasts (FC6 and FC8 one) there
Put starters socket onto the lid (opposite to the thread socket)
