Author Topic: Is this a remote ballast?  (Read 3372 times)
CreeRSW207
Is this a remote ballast? « on: February 03, 2020, 07:56:09 PM » Author: CreeRSW207
This pole had a Holophane RSL 200 and an AEL 125. Looks like a 250w MV remote ballast.
Power Company: Eversource
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: Is this a remote ballast? « Reply #1 on: February 03, 2020, 10:52:49 PM » Author: HPS_250
Looks to be a remote ballast to me! You can see the blue 25 sticker. I wonder what this is for though, because AEL 125s have built in ballasts. Do the Holophane RSL 200 have it’s own ballast?
CreeRSW207
Re: Is this a remote ballast? « Reply #2 on: February 04, 2020, 06:12:18 PM » Author: CreeRSW207
Don't think so I see most of these with remote ballasts.
HPS_250
Re: Is this a remote ballast? « Reply #3 on: February 04, 2020, 07:04:07 PM » Author: HPS_250
Then this is a ballast.
Re: Is this a remote ballast? « Reply #4 on: February 05, 2020, 12:15:54 AM » Author: joseph_125
The thick insulated wires and the abandoned insulators on the pole makes me think this used to be part of a series streetlighting circuit that got removed and the remote mounted isolation ballasts just abandoned in place.
CreeRSW207
Re: Is this a remote ballast? « Reply #5 on: February 05, 2020, 07:02:17 AM » Author: CreeRSW207
Before the holophane or the AEL could have been a MV gumball.
HPS_250
Re: Is this a remote ballast? « Reply #6 on: February 05, 2020, 09:26:12 AM » Author: HPS_250
It does sound like there could have been series gumballs here.
WestinghouseCeramalux
Re: Is this a remote ballast? « Reply #7 on: February 12, 2020, 07:52:04 PM » Author: WestinghouseCeramalux
Makes no sense to mount ballasts on a HV cross board. Would you want to work next to 15kV + lines changing out a ballast if it failed? Rule of thumb with power lines is that the highest voltage goes on top, and as the lines get lower the voltage is also lower.
As to what these are, they're most likely capacitors.
« Last Edit: February 12, 2020, 07:53:53 PM by WestinghouseCeramalux » Logged
CreeRSW207
Re: Is this a remote ballast? « Reply #8 on: February 12, 2020, 08:08:04 PM » Author: CreeRSW207
Makes sense, this line is 15kv?
Re: Is this a remote ballast? « Reply #9 on: February 12, 2020, 11:33:21 PM » Author: WestinghouseCeramalux
It looks like it's around there...15kV is just an estimate.
CreeRSW207
Re: Is this a remote ballast? « Reply #10 on: February 13, 2020, 07:19:05 AM » Author: CreeRSW207
I'm not good at telling voltage on power lines I usually look to someone else.
Re: Is this a remote ballast? « Reply #11 on: February 13, 2020, 08:33:19 AM » Author: sox35
Over here, wires like that would be 11kV so possibly 15kV, yes.
