Author Topic: Hospital Room Lights  (Read 3133 times)
LightUpMyLife
https://www.facebook.com/ https://twitter.com/TedTa
Hospital Room Lights « on: January 24, 2020, 09:22:09 PM » Author: LightUpMyLife
What do you call those lights you find on the back wall of patient rooms at the hospital that can shine up and down, and what is the purpose for those lights?
Re: Hospital Room Lights « Reply #1 on: January 24, 2020, 09:36:50 PM » Author: Cole D.
I always figured they were for the patient to read in bed, or for diffused lighting at night when nurses make their rounds without being too bright.
Re: Hospital Room Lights « Reply #2 on: February 02, 2020, 04:06:56 PM » Author: Ash
Some points other than the reading lamp :
Many times patients need to awaken periodically at night for some treatment, many times its small things ranging from changing IV bags to requiring help to get out of bed to use the bathroom. While at that, the others in the same room dont want to be disrupted from their sleep by switching on the main lights
Some sorts of illness (pretty much anything that comes with high body temperature..) tend to also cause very high sensitivity to light - Where light (at levels which are otherwise normal) or minor glare (from otherwise diffused and indirect light sources) can trigger headaches. The light output of the small lamp (typically few 100's Lm, so 40W GLS or 7..10W PL) is about right for comfortable light under those conditions
Patients at hospital are not at home and dont feel well, and generally having night lighting helps reduce anxiety and stress
Atleast here, The luminaire itself had been traditionally (up to 80s) a lamp with adjustable arm (like an architect's desk lamp) with 40W GLS. In the 80s and 90s it was mostly wall sconce with PL that can be turned up or down. in the 2000s a non movable PL luminaire integrated into the wall panel (where the oxygen supply etc are), which i think are less functional than the 2 former solutions
Re: Hospital Room Lights « Reply #3 on: February 02, 2020, 06:45:56 PM » Author: sol
I believe this post relates to a relatively high intensity fluorescent fixture above the headboard.
Here, they use a special fixture that has two F32T8 lamps that shine downwards, and two that shine upwards. The upwards ones are articulated and can be flipped to shine down as well (4xF32 shining down). The down light is for reading and also for examining. If the doctor or nurse wants more light than two lamps, it is easy as flipping a lever. The switch is usually a pull chain with a long string attached to the bed so the patient can control it. The switch is a standard 3-level where you pull 1. for the bottom light, 2. for the top light, 3. for both and 4. all off. Most fixtures have heavily blackened lamps because of all that switching, though.
I searched online for a picture but couldn't find any. Integrated LED fixtures have taken over now.
Night lights can be integrated into this unit, but the hospital here doesn't have them.
LightUpMyLife
Re: Hospital Room Lights « Reply #4 on: February 02, 2020, 07:50:17 PM » Author: LightUpMyLife
Most of our hospitals have little bedside controllers that can adjust the bed, control the TV, intercom with a nurse, and control both the up and down lights in one device, but I don't know what you call that either.
LampLover
120/240VAC @ 60HZ
Re: Hospital Room Lights « Reply #5 on: February 04, 2020, 08:31:43 PM » Author: LampLover
They are called Pillow Speakers and Curbell Medical is one of the most known makers of such a device
I vaguely remember my 47 day hospital stay in 2005 (I had a really bad case of pneumonia and almost died), but here I am today alive and well. Anyway a lot (but not all) of the hospital beds are made by hillrom the technology today is so advanced then what is was 15 years ago when I was in the ICU. They had those lights sol said they looked to have program start ballasts as they are frequently switched by the staff and the patient. The last time I was in that hospital (August 2019 ER visit) most of the lights are now LED
LED Free Zone!
Re: Hospital Room Lights « Reply #6 on: February 04, 2020, 08:34:57 PM » Author: sol
The ones here are instant start. The tube ends are very blackened ; I imagine they don't last very long due to the switching cycle every time it is turned on or off.
Re: Hospital Room Lights « Reply #7 on: February 05, 2020, 10:49:53 AM » Author: HomeBrewLamps
The hospital here has 4XF40 troffers in the ceiling, a wall fluorescent lamp with a single tube in it and then night lights
There is usually three or 4 troffers to a room.
The wall fluorescent fixture is controlled by a switch on the bed.
There is usually 2 night lights in a room. One near the window and one near the door. They're usually low wattage incandescent lamps like 15 watt.
~Owen
Re: Hospital Room Lights « Reply #8 on: February 15, 2020, 07:02:46 PM » Author: Ash
For ceiling lights, the hospital in Nahariya uses Gaash 4300 and 4400 based strips (Europa versions on lower floors and Speedpack versions on higher, later built floors) with refractor box attachment. The box allows only downwards light, but it is diffused
4300s (1 36/40W tube) above bed's heads and 4400s (2 tubes) above the walkway along the opposite wall
I dont think they are any special version made for hospitals, its just that the hospital architect chose them and they fit well (back in the 80s when it was built)
