Author Topic: Help to ID lamp  (Read 4239 times)
Edmund Ironside
Help to ID lamp « on: January 16, 2020, 02:20:11 PM » Author: Edmund Ironside
 ???Greetings sirs and madams!
I need some help to ID a lamp that i do not yet own. I have been promised it but i cant figure out what type of lamp it is based on the pictures ive been shown. The person handling it does not know anything of lamps and can not help me to ID it. Id like to know what typ it is so i can make preparations before i get it and start to read up on it.
Im posting two pictures hoping anyone know what type of lamp it is.
Made in Sweden
Rich, Coaster junkie!
Re: Help to ID lamp « Reply #1 on: January 17, 2020, 03:51:02 PM » Author: AngryHorse
Could it be some form of photo flash lamp?
Current: UK 230V, 50Hz
Power provider: e.on energy
Longest serving LED in service at home, (hour count): Energetic mini clear globe: 56,654 hrs @ 14/9/24
Welcome to OBLIVION
Edmund Ironside
Re: Help to ID lamp « Reply #2 on: January 18, 2020, 03:36:36 AM » Author: Edmund Ironside
Looking at the Arc-tube and the four pin base this could be it maybe?
Where would a flash bulb this size would have been used, it is a huge bulb. What kind of gear does these run on? Some kind of capacitor discharge or HV pulse?
Made in Sweden
Re: Help to ID lamp « Reply #3 on: January 18, 2020, 05:39:31 AM » Author: AngryHorse
If it is, it’ll be for commercial photography studio’s, or it could also be a strobe used in tv or film making?
Welcome to OBLIVION
Edmund Ironside
Re: Help to ID lamp « Reply #4 on: January 26, 2020, 02:37:10 PM » Author: Edmund Ironside
UPDATE!
It is a stroboscope lamp, and it is now safe in my colletion. It is a Philip's made lamp. 1953 vintage, so quite old. Made in Holland. It is a Philips Type 57900 P/06, cant find any references to it in the Philips catalouges on Lamptech.
Anyone have any ideas or info? It is quite large, with a big arc-tube. How would one test this bulb without highly specialised equipment? A big capacitor?
Made in Sweden
Re: Help to ID lamp « Reply #5 on: January 26, 2020, 03:14:20 PM » Author: sox35
UPDATE!
One of these might work, it uses 3kV at 280kHz to check if an arc tube is ok. Works on normal discharge lamps, don't know about this one though.
migette1
Peter
migette1
Re: Help to ID lamp « Reply #6 on: January 27, 2020, 06:32:22 AM » Author: migette1
Take my advice be very careful trying to light certain lamps unless you really know the gear is correct, better off just keep the lamp in collection be a pity to blow it.BTW the value of lamps is going up the whole time and as I have said better then money in the bank.
Interested in the history of electric lighting and incandescent in particular and neon glow lamps.
Edmund Ironside
Re: Help to ID lamp « Reply #7 on: January 28, 2020, 02:39:52 PM » Author: Edmund Ironside
Ill follow your advise Migette.
Do you know anything about the lamp? Do you have any good sources for vintage Philips catalouges?
Made in Sweden
