Author Topic: Making A Pencil Lead into a Light - Very cool!  (Read 12977 times)
lightman64
Making A Pencil Lead into a Light - Very cool! « on: January 01, 2009, 08:15:51 PM » Author: lightman64
here is the link : http://www.youtube.com/watch?v=iG0_LAefrnI&feature=related
form109
Re: Making A Pencil Lead into a Light - Very cool! « Reply #1 on: January 01, 2009, 08:46:06 PM » Author: form109
i,ve tried this experiment several times before,i used 0.7 MM lead for those mechanical pencils,i got the best results driving it with a 24 Volt 2 Amp power supply,i made supports for the rod so it wouldnt break when it got very hot.
lightman64
Re: Making A Pencil Lead into a Light - Very cool! « Reply #2 on: January 02, 2009, 09:41:11 AM » Author: lightman64
i think you have to use wooden pencil lead instead of mechainial pencil lead. but, i guess that works too!  ;D
form109
Re: Making A Pencil Lead into a Light - Very cool! « Reply #3 on: January 02, 2009, 01:48:08 PM » Author: form109
besides being easier to obtain,the mechanical pencil lead is thinner and has less resistance which means it heats more and glows white instead of orange.
SeanB~1
Re: Making A Pencil Lead into a Light - Very cool! « Reply #4 on: January 02, 2009, 03:31:41 PM » Author: SeanB~1
I made arc lamps using the graphite rod from a old "D" cell, driven from 28V. Aside from the brilliant white light, it blanked out radio reception for meters around my workbench, whilst I used it to weld aluminium plate.
form109
Re: Making A Pencil Lead into a Light - Very cool! « Reply #5 on: January 02, 2009, 06:58:41 PM » Author: form109
yep,i didnt think arcs could form at such low voltage i used it to melt coins.
Re: Making A Pencil Lead into a Light - Very cool! « Reply #6 on: January 08, 2009, 09:35:11 PM » Author: icefoglights
I've also tried an arc light too, using lead from a mechanical pencil and a 9 volt battery.
form109
Re: Making A Pencil Lead into a Light - Very cool! « Reply #7 on: January 08, 2009, 10:01:10 PM » Author: form109
if you really want to make a carbon arc lamp,you could use carbon rods from a battery,i know of some transformers that can supply 12 volts at 35 amps,50 amps short circuit!!!  :o
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: Making A Pencil Lead into a Light - Very cool! « Reply #8 on: January 25, 2009, 08:23:56 PM » Author: Foxtronix
Hey Sean you opened a cell? Isn't there any stuff that can burn the skin?
SeanB~1
Re: Making A Pencil Lead into a Light - Very cool! « Reply #9 on: January 26, 2009, 02:56:41 PM » Author: SeanB~1
Yes, the contents can burn. I gently squeezed the cell in a vice a few times to loosen the grip around the rod, then withdrew it using pliers to grip the metal tip. It comes out mostly clean, just needing a little washing in cold water with washing soap. I used ordinary cheap cells, not the alkaline type, as these are a totally different construction.
Foxtronix
Re: Making A Pencil Lead into a Light - Very cool! « Reply #10 on: January 26, 2009, 05:45:29 PM » Author: Foxtronix
Sean: OK I don't have anything else than alkaline cells. Instead I use the lead in a wooden pencil. I attached two leads to a wire and hooked up the wires to a transformer that supply 40V and 2,5A. You make a contact between them during 1/4 of a second and voila! An arc starts, and that's BRIGHT!! Unfortunately many problems occurs:
- The negative rod burns pretty fast
- The arc isn't steady for more than 7 sec. and shuts off after 12 sec.
- There is an important color shift at the end, sometimes one of the wire melt.
- A lot of smoke is produced
