lightman64
The future of street lighting is Induction, not nasty HPS lights or cr@ppy LED lights! Preheat CFL's should make a comeback!
form109
i,ve tried this experiment several times before,i used 0.7 MM lead for those mechanical pencils,i got the best results driving it with a 24 Volt 2 Amp power supply,i made supports for the rod so it wouldnt break when it got very hot.
lightman64
i think you have to use wooden pencil lead instead of mechainial pencil lead. but, i guess that works too!
form109
besides being easier to obtain,the mechanical pencil lead is thinner and has less resistance which means it heats more and glows white instead of orange.
SeanB~1
I made arc lamps using the graphite rod from a old "D" cell, driven from 28V. Aside from the brilliant white light, it blanked out radio reception for meters around my workbench, whilst I used it to weld aluminium plate.
form109
yep,i didnt think arcs could form at such low voltage i used it to melt coins.
I've also tried an arc light too, using lead from a mechanical pencil and a 9 volt battery.
form109
if you really want to make a carbon arc lamp,you could use carbon rods from a battery,i know of some transformers that can supply 12 volts at 35 amps,50 amps short circuit!!!
Foxtronix
Hey Sean you opened a cell? Isn't there any stuff that can burn the skin?
SeanB~1
Yes, the contents can burn. I gently squeezed the cell in a vice a few times to loosen the grip around the rod, then withdrew it using pliers to grip the metal tip. It comes out mostly clean, just needing a little washing in cold water with washing soap. I used ordinary cheap cells, not the alkaline type, as these are a totally different construction.
Foxtronix
Sean: OK I don't have anything else than alkaline cells. Instead I use the lead in a wooden pencil. I attached two leads to a wire and hooked up the wires to a transformer that supply 40V and 2,5A. You make a contact between them during 1/4 of a second and voila! An arc starts, and that's BRIGHT!! Unfortunately many problems occurs:
- The negative rod burns pretty fast - The arc isn't steady for more than 7 sec. and shuts off after 12 sec. - There is an important color shift at the end, sometimes one of the wire melt. - A lot of smoke is produced
