Author Topic: Can Metal Halide lamps be used indoors ?  (Read 3770 times)
Jovan
Can Metal Halide lamps be used indoors ? « on: December 25, 2019, 03:47:30 PM » Author: Jovan
Hello to everyone.Do you use MH lights indoors and are they reliable and how long they last ?
Re: Can Metal Halide lamps be used indoors ? « Reply #1 on: December 26, 2019, 12:03:13 AM » Author: dor123
I've a 70W double ended MH tracklight in my room at my hostel and three 70W double ended MH lamps of Sylvania, Osram and Venture.
Jovan
Re: Can Metal Halide lamps be used indoors ? « Reply #2 on: December 26, 2019, 07:59:56 AM » Author: Jovan
Is this too bright for room and is CRI good ?
Re: Can Metal Halide lamps be used indoors ? « Reply #3 on: December 26, 2019, 08:07:29 AM » Author: dor123
It is very bright. The CRI is dependent on the halide chemistry inside the lamp.
Re: Can Metal Halide lamps be used indoors ? « Reply #4 on: December 26, 2019, 09:10:14 AM » Author: Mandolin Girl
You have to remember that with discharge lighting, they don't like frequent switching, and they need to be run for at least 4 or 5 hours at a time. Preferably only one or two switching cycles a day.
Re: Can Metal Halide lamps be used indoors ? « Reply #5 on: December 26, 2019, 10:16:03 AM » Author: Cole D.
Some stores use MH fixtures indoors, in troffers and high/low bays.
Re: Can Metal Halide lamps be used indoors ? « Reply #6 on: December 26, 2019, 11:02:42 AM » Author: Mandolin Girl
Yes, but they will be only switched once a day and will be run for a long time.
Jovan
Re: Can Metal Halide lamps be used indoors ? « Reply #7 on: December 26, 2019, 04:36:07 PM » Author: Jovan
So it is ideal for shops and museums.
Jovan
Re: Can Metal Halide lamps be used indoors ? « Reply #8 on: December 26, 2019, 04:37:36 PM » Author: Jovan
As I saw these lamps have good CRI (80 or better) and long life.
Jovan
Re: Can Metal Halide lamps be used indoors ? « Reply #9 on: December 26, 2019, 04:39:46 PM » Author: Jovan
That is good.If lamp has Hg inside the arc tube,CRI should be lower ,right ?
Re: Can Metal Halide lamps be used indoors ? « Reply #10 on: December 26, 2019, 05:00:37 PM » Author: sox35
Yes, they are ideal for that  8)
Re: Can Metal Halide lamps be used indoors ? « Reply #11 on: December 27, 2019, 02:06:40 AM » Author: HomeBrewLamps
I regularly light all sorts of lamps from 7 to 1500 watts in my house with no I'll effects.
~Owen
Jovan
Re: Can Metal Halide lamps be used indoors ? « Reply #12 on: December 27, 2019, 03:54:05 PM » Author: Jovan
In winter times you have heat and light in one.
Re: Can Metal Halide lamps be used indoors ? « Reply #13 on: December 27, 2019, 05:33:08 PM » Author: sox35
We know all about that, the 400W HPS and 1000W MV lamps we have are excellent space heaters  ;D :D
