Author Topic: Philips TL-S Fluorescent Lamps  (Read 7275 times)
Miles
Philips TL-S Fluorescent Lamps « on: December 17, 2019, 02:00:57 PM » Author: Miles
I know that France had these unique T12 fluorescent bulbs made popular mid-20th century, and they were available usually in 2 foot 20W and 4 foot 40W, single contact R18 socket. There were rapid start with an internal ignition strip.
A long time ago, a small local market was renovating and tearing down their lighting. The shop had these old tired 2-lamp fixtures, however, the tubes were about 72 inches long (180cm). I had a 40W version of that fixture, same sockets, same design and all, and I'm pretty sure the ends were for a R18 socket, therefore a TL-S lamp.
I never ever heard of a TL-S lamp longer than 4 foot (120cm) at 40W. Is my memory wrong, or did that particular lamp was also made in a 6 foot long version?
Note: For those who want to see how they look like, here's a link :)
« Last Edit: December 17, 2019, 02:02:28 PM by Miles » Logged
Silverliner
Rare white reflector
Re: Philips TL-S Fluorescent Lamps « Reply #1 on: December 17, 2019, 11:05:24 PM » Author: Silverliner
Checked a couple Philips catalogs. They only listed TL-S up to 40w. Perhaps the ones you saw were slimline?
http://www.lamptech.co.uk/Catalogues.htm
Plenty of great literature in the above link.
Member of L-G since 2005.
Electrician.
Miles
Re: Philips TL-S Fluorescent Lamps « Reply #2 on: December 18, 2019, 06:40:57 PM » Author: Miles
So that's just it, I thought the same thing, 40W is the max. And you're right, catalogs only list 40W as the largest you can get.
Definitely not a Slimline as it had no brass in a single pin, it was a dark bakelite end where you remove the bulb by turning ¼ turn, just like TL-S. However, you could say that then this likely was an HO RDC lamp, but the tube had an inner ignition strip, and was longer than 4 foot. I remember measuring it totaling at about 180cm or about 72 inches.
Silverliner
Re: Philips TL-S Fluorescent Lamps « Reply #3 on: December 19, 2019, 11:57:04 PM » Author: Silverliner
Were 75w 6' T12 bipin lamps ever used in France by any chance? Or just a British thing?
Electrician.
Re: Philips TL-S Fluorescent Lamps « Reply #4 on: December 21, 2019, 06:07:12 PM » Author: James
As far as I know the TL-S indeed only existed in 2ft 20W and 4ft 40W.  If you remember it having black end caps, I can only wonder if it might have been an HO 110W or VHO 215W tube, but as far as I know Philips only made these in 8ft length and with R17d caps.
Dave - the 6ft tube is an exclusively British thing, even the modern T8 6ft 70W never seemed to take off in other countries.
Silverliner
Re: Philips TL-S Fluorescent Lamps « Reply #5 on: December 21, 2019, 06:22:49 PM » Author: Silverliner
James, we have a small number of 70w 6’ T8s here in the states. Used in refrigeration equipment.
Electrician.
Michael
Re: Philips TL-S Fluorescent Lamps « Reply #6 on: December 22, 2019, 03:20:37 AM » Author: Michael
The same here, I’ve only seen this size in refrigerators. The TL-S and maybe the TL-R format were maybe a thing in the 50s- 60s here but never seen any installed.
For the VHO Power Groove it’s different. The 215W size were in the past quite common in Switzerland.
Miles
Re: Philips TL-S Fluorescent Lamps « Reply #7 on: December 23, 2019, 11:15:44 PM » Author: Miles
The thing that bothers me is that I definitely know it was not a bipin prong end (no exposed brass or metal), it had an internal ignition strip.
HO or VHO are 8 feet and too long, this was closer to 6 feet. And to remove, it was ¼ turn click, no plungers. Fixture had the sockets in a V config with "Cie Des Lampes" stamped at the end.
Jovan
Re: Philips TL-S Fluorescent Lamps « Reply #8 on: December 24, 2019, 11:37:10 AM » Author: Jovan
Where these lamps were used ?
Re: Philips TL-S Fluorescent Lamps « Reply #9 on: December 26, 2019, 11:18:13 AM » Author: sox35
I'm hoping to get a few of these lamps soon, I already have the ballast lamps  8)
Mr. Orthosilicate
Re: Philips TL-S Fluorescent Lamps « Reply #10 on: December 27, 2019, 09:17:47 PM » Author: Mr. Orthosilicate
There is a whole case of 25 TLS 40w/33 lamps on U.S. eBay for some reason. There is also a set of 4. They’re quite expensive though. I can’t imagine what the shipping would be to get them across the pond.
Case: https://www.ebay.com/itm/Lot-of-25-Philips-TLS-40W-33-Fluorescent-Tube-Lamp-Light-Bulb-Cool-White-R18S/152329263492?epid=2079213165&hash=item2377881984:g:a~0AAOSw-0xYNc4T
4 Lamps: https://www.ebay.com/itm/Lot-of-4-Philips-TLS-40W-33-Fluorescent-Tube-Lamp-Light-Bulb-Cool-White-R18S/152329291406?epid=2079213165&hash=item237788868e:g:a~0AAOSw-0xYNc4T
Re: Philips TL-S Fluorescent Lamps « Reply #11 on: December 28, 2019, 09:51:01 AM » Author: sox35
Interesting to see them over there, but the shipping costs are too much to get them here. I have found a supplier in France who I hope to get some from in the New Year, will post more details when I have information.
Miles
Re: Philips TL-S Fluorescent Lamps « Reply #12 on: January 08, 2020, 09:46:13 PM » Author: Miles
Do you have fixtures for them?
Re: Philips TL-S Fluorescent Lamps « Reply #13 on: January 09, 2020, 07:21:20 AM » Author: sox35
Unfortunately not, but I remember them from my childhood, a local shop had one in the front window.
Miles
Re: Philips TL-S Fluorescent Lamps « Reply #14 on: January 11, 2020, 08:42:14 PM » Author: Miles
I regret tossing the 2x40W fixture and bulbs I had at the time. But what the hell did I know, I was 9. :-X
