Author Topic: 175 watt M400  (Read 6491 times)
CreeRSW207
175 watt M400 « on: December 10, 2019, 06:00:35 PM » Author: CreeRSW207
Never expected to see a 175 watt version of this light.
Power Company: Eversource
fluorescent lover 40
Re: 175 watt M400 « Reply #1 on: December 10, 2019, 06:51:15 PM » Author: fluorescent lover 40
MV or MH? I know of some GE 150w HPS GE M-400s but they got replaced  a couple of months ago.
CreeRSW207
Re: 175 watt M400 « Reply #2 on: December 10, 2019, 09:18:17 PM » Author: CreeRSW207
It is HPS.
Re: 175 watt M400 « Reply #3 on: December 10, 2019, 10:05:38 PM » Author: Lumex120
It is HPS.
175w HPS doesn't exist... at least not anymore (it was a thing when HPS was first coming around).
Unofficial LG Discord
CreeRSW207
Re: 175 watt M400 « Reply #4 on: December 11, 2019, 06:13:53 PM » Author: CreeRSW207
It has a silver Nema tag, if not HPS it must be MH
Re: 175 watt M400 « Reply #5 on: December 11, 2019, 06:36:25 PM » Author: joseph_125
I agree with it being MH, the red on the NEMA tags tend to fade over the years. The ones on the gumballs here have faded to a white background.
I guess it might have been a unlisted option that GE offered. GE had a lot of special order options and even fixtures that weren't listed in the catalogue but you could order if you knew the ordering code. The Crimefighters was one example, they were originally made for the City of Chicago but I believe others could have ordered them if you knew the ordering code as I've seen some in the wild in Canada.
CreeRSW207
Re: 175 watt M400 « Reply #6 on: December 11, 2019, 06:53:18 PM » Author: CreeRSW207
I think it was a order option because there are more of these down the road and they all have no signs of red.
Re: 175 watt M400 « Reply #7 on: December 11, 2019, 06:57:47 PM » Author: wide-lite 1000
According to the spec sheet these were available in wattages all the way down to 70 watt !
See HERE: https://products.currentbyge.com/sites/products.currentbyge.com/files/documents/document_file/OLP2925-GE-M400-MSRL-MSRA-Roadway-HID-Data-Sheet.pdf  Page 3
Re: 175 watt M400 « Reply #8 on: December 11, 2019, 07:16:33 PM » Author: fluorescent lover 40
Imagine a 35w HPS GE M-400?
CreeRSW207
Re: 175 watt M400 « Reply #9 on: December 11, 2019, 07:57:07 PM » Author: CreeRSW207
Imagine a 35 watt M1000!
Re: 175 watt M400 « Reply #10 on: December 11, 2019, 08:25:56 PM » Author: wide-lite 1000
AN OVERSIZED NIGHTLIGHT !  :D
CreeRSW207
Re: 175 watt M400 « Reply #11 on: December 11, 2019, 08:49:24 PM » Author: CreeRSW207
Seriously!
Re: 175 watt M400 « Reply #12 on: December 11, 2019, 09:46:47 PM » Author: Lumex120
Early GE PSMH fixtures had white NEMA labels which can look silver. I'm thinking these might be older PSMH lights. can you try and get a good picture from underneath one?
CreeRSW207
Re: 175 watt M400 « Reply #13 on: December 12, 2019, 03:03:29 PM » Author: CreeRSW207
One from Google Earth.
CreeRSW207
Re: 175 watt M400 « Reply #14 on: December 12, 2019, 08:31:17 PM » Author: CreeRSW207
Light is in the same to that may convert to LED. But if I see the crew (not likely though since it’s in Maine) I’ll see if I can get it.
« Last Edit: December 12, 2019, 08:33:50 PM by CreeRSW207 » Logged
