lightman64
after a while, why do the actual tubing on a cfl turn blackish?
Mr. Big
I've seen a few that did that, I had one that did that too, lasted for quite a long time after too!
lightman64
iv'e had one that turned a little black on a timer for a while and it seems to work okay.
« Last Edit: December 20, 2008, 09:46:33 AM by lightman64 »
Mercury Man
CFLs seem to dim out over time, due to the slight blackening of the tube. If you replace a CFL with a lot of hours on it with a brand new one of the same wattage, the light will be about 20% brighter! I've noticed this with several CFLs from different manufacturers.
Foxtronix
The low diameter of the tube (T3 and now becoming T2) can explain a fast blackening. I also suppose that the high voltage pulse used to start the lamp makes a lot of sputerring from the electrodes.
lightman64
ok. but i thought only some cfls use high pulses of energy when the fist start; also i thought that this problem was being phased out.
Foxtronix
It's only a supposition. I don't know how the CFL gears works.
lightman64
thats ok ; i was just saying...
lightman64
i actually think that it is the sputter from the electrodes because mos cfls i use are instant start. this makes the electrodes sputter, kinda like on a MV lamp.
Foxtronix
That's why I believe that an high voltage pulse used to start the CFL...
form109
some of my Cfl's are programed start,i like those better than instant start.
TudorWhiz
The current GE spirals that has "instant start" some of them seem to be more of a "quick programmed start"
lightman64
that is exactly what happens. guess they got the wrong ballast!
lightman64
The newer cfls that are on the market don't blacken as quickly. I have a N:Vision EXDO-13 from about 3 years ago that is on every night in one of my porch lights (my 1st cfl) and it hasn't blackened yet. On the other hand i have a 4 or 5 year old EDSO-14 commercial electric that was the preivous model to the EXDO-13 and it is blackened from about 5 hrs of use per day compared to on all night with 3 years.
