Author Topic: Thorn Gamma 6 Post Top lantern - conversion  (Read 3469 times)
Thorn Gamma 6 Post Top lantern - conversion « on: October 24, 2019, 05:54:09 PM » Author: Mandolin Girl
I've just purchased a Thorn Gamma 6 lantern, that will arrive in the middle of next week.
It's going to be easier to make this into a floor lamp as it's a post top lantern.
I reckon all I'll need is a post of the correct diameter and a pot to put it in, then I will use some of the grit, from the gritting bin across the road as that sets hard, to keep the post upright.
Then we will be in business.  8)
Looking at this website I'm pretty sure that the lantern I'm getting is from the '90s.
« Last Edit: October 24, 2019, 06:18:18 PM by Mandolin Girl » Logged
HPSM250R2
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #1 on: October 24, 2019, 06:18:08 PM » Author: HPSM250R2
Awesome what wattage lamp?
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #2 on: October 24, 2019, 06:19:17 PM » Author: Mandolin Girl
35W  8) SOX of course  ;D
HPSM250R2
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #3 on: October 24, 2019, 06:28:33 PM » Author: HPSM250R2
Ahh awesome. Can't wait to see it. I'm just sorry I didn't get into SOX lighting until recently. I've been missing out.
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #4 on: October 24, 2019, 06:30:48 PM » Author: Mandolin Girl
I don't think a 180W one would fit  :D :P
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #5 on: October 24, 2019, 06:31:02 PM » Author: Mandolin Girl
I'll be sure to post pictures when it's done.   :) The seller wants to see pics as well.!  :)
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #6 on: October 24, 2019, 06:37:46 PM » Author: Ash
I have used posttops as room lantens before -
Steinitz moon baloon (first time with its original 125W Merc, later converted to 13W PL-C with an Orion adapter, running in series with the Merc gear)
Ben Hur Rondolux clone (acually put together from parts of the Ben Hur clone and real AEG Rondolux lanterns) (converted to 26W PL-C)
Gaash 600mm cone (converted to 9W PL-S)
The moon baloon is fairly lightweight lantern (and even more so if i would remove the ballast), it fared well standing on the base from a floor fan
The 2 others are big lanterns that would tip over if wobbled - For them i used a real 2" pipe (same as the pole they are meant for), standing on the floor and attached to a side bracket thats screwed to the wall (to holes remaining from a shelf that was there many years ago). Still had to be careful not to bump them but otherwise it was usable
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #7 on: October 31, 2019, 03:22:22 PM » Author: Mandolin Girl
The lantern arrived today, so the work can now start. I have still to source the 3" post though.  :)
Tha SOX MADMANNN
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #8 on: October 31, 2019, 09:16:09 PM » Author: 589
Heavy gauge pvc pipe? Around here it can be had in black also. Expanding foam can possibly be used as further internal structure stiffening. Also an old brake rotor from a truck works good for a base.
:lps:
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #9 on: October 31, 2019, 09:18:49 PM » Author: Mandolin Girl
Good suggestion, for a base I was thinking of a waste paper bucket and lots of road grit from the bin across the road.
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #10 on: October 31, 2019, 10:36:33 PM » Author: wide-lite 1000
 sounds like a good plan !
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #11 on: November 08, 2019, 01:31:12 PM » Author: Mandolin Girl
We have got the lamp on a temporary base, sitting on a shelf in the corner of the living room. ;D
Re: Thorn Gamma 6 Post Top lantern - conversion « Reply #12 on: November 26, 2019, 03:28:41 PM » Author: Mandolin Girl
We had considered putting the lantern on a 3" Heavy wall ABS pipe from a local plumber's merchant, but when we went past there today they have gone from that location.  :(
They have either moved or gone out of business.  :-\
Gemma is quite happy where she is for the moment though.  ;)
« Last Edit: November 26, 2019, 03:33:13 PM by Mandolin Girl » Logged
