Author Topic: Should I use dimmable LED bulbs as replacement for incandescent lamps ?  (Read 11772 times)
Re: Should I use dimmable LED bulbs as replacement for incandescent lamps ? « Reply #15 on: October 18, 2019, 04:06:44 PM » Author: Ash
That is awesome
jrmcferren
Re: Should I use dimmable LED bulbs as replacement for incandescent lamps ? « Reply #16 on: October 31, 2019, 07:35:22 AM » Author: jrmcferren
Be aware though, normal incandescent dimmers don’t suit LED, you would also need a special LED dimmer switch along with the lamps  ;)
Compatibility is not easy to determine. I have a LED compatible dimmer that doesn't like some LEDs (it doesn't always trigger and I get a quick blip in the light sometimes every few seconds), yet I have another dimmer that does not state LED compatibility, yet works 100%.
I also buy dimmable LED lamps as standard instead of non-dimmable. Usually the dimmable ones are better made and come in more desirable styles when buying locally (such as filament type even in GLS replacements). Dimmable lamps will of course work on non-dimming circuits.
Re: Should I use dimmable LED bulbs as replacement for incandescent lamps ? « Reply #17 on: October 31, 2019, 11:47:42 PM » Author: RyanF40T12
I've had a hard time finding a good dimmer for LED bulbs.  I got a few Feit Electric LED dimmer switches but on only one or two bulbs they often will flicker or hyper flicker despite there being a auto adjust/calibrate button.  When I have more than two dimable LED bulbs on a switch they don't seem to flicker.
Re: Should I use dimmable LED bulbs as replacement for incandescent lamps ? « Reply #18 on: November 01, 2019, 01:50:07 PM » Author: Ash
Just visited Photobucket. The entire CMS they use is one big web2.0 Javascript...
marcopete87
Re: Should I use dimmable LED bulbs as replacement for incandescent lamps ? « Reply #19 on: November 03, 2019, 02:32:59 PM » Author: marcopete87
Hi, i'm using now some Ikea Tradfri lamps (which can be paired to a remote control), i would change dimmer with a switch and let one remote dimming all lamps.
Jovan
Re: Should I use dimmable LED bulbs as replacement for incandescent lamps ? « Reply #20 on: November 04, 2019, 04:55:22 PM » Author: Jovan
Are you satisfied with them ?
