Author Topic: Can you run 125 watt mercury lamps on 100w MH ballast?  (Read 2998 times)
Can you run 125 watt mercury lamps on 100w MH ballast? « on: October 11, 2019, 04:51:50 PM » Author: HomeBrewLamps
I've come to the realization that the "70 watt" metal halide ballast I have is actually an M90 ballast. Can it run anything other than 100 watt metal halides? I only intend on stocking 70 and 175 watt variants so this ballast may well be useless if I can't find another lamp type.
I've been mistakenly running 70 watt halides and 100 watt mercury lamps on it.
~Owen
fluorescent lover 40
Re: Can you run 125 watt mercury lamps on 100w MH ballast? « Reply #1 on: October 11, 2019, 04:58:00 PM » Author: fluorescent lover 40
Yes. 35w runs 50w MV. 70w runs 100w MV and 100w runs 125w MV. Disconnect the ignitor on all.
Jovan
Re: Can you run 125 watt mercury lamps on 100w MH ballast? « Reply #2 on: October 11, 2019, 05:16:12 PM » Author: Jovan
Why you need to run MV lamps on lower wattage when fitted with HPS/MH ballast.For example why you have to run 50W on 35W ?50w is 50W right ?
Re: Can you run 125 watt mercury lamps on 100w MH ballast? « Reply #3 on: October 11, 2019, 05:23:09 PM » Author: HomeBrewLamps
Alright that's good to know! That means I could stock some European lamps now. Although not at the top of my priorities right now...
~Owen
Re: Can you run 125 watt mercury lamps on 100w MH ballast? « Reply #4 on: October 12, 2019, 02:46:32 AM » Author: Ash
Atleast over here Pulse Start MH lamps in the low power ratings follow HPS specs. So for the same power they are higher current lamps than Mercs. The current is about right for 1 step higher power Merc lamp
Men of God
jiachao.wei.71 chao_813975447 UChyTpXvlQ8ZCfBPP_lJjubg chao990613
Re: Can you run 125 watt mercury lamps on 100w MH ballast? « Reply #5 on: January 11, 2020, 01:27:15 PM » Author: Men of God
据我网友说他们那最早期时是125W外镇流型汞灯,然后后来换成了110W钠灯,触发器直接串联在原来的汞灯镇流器上,没有更换镇流器。
我不会英文,所以我用中文,请你们用翻译网站翻译我打的字!
I can't in English, so I in Chinese, please use the translation website to translate my words!
