Author Topic: Correct Ballast for F20T9 & F30T8/CW/4  (Read 2785 times)
Mr. Orthosilicate
Correct Ballast for F20T9 & F30T8/CW/4 « on: October 04, 2019, 10:56:47 PM » Author: Mr. Orthosilicate
I was wondering what the correct ballasts are for the F20T9 lamp and the F30T8/CW/4 (which is a 19w 30in lamp). Do they operate on normal 120v choke ballasts for 20w lamps?
Men of God
jiachao.wei.71 chao_813975447 UChyTpXvlQ8ZCfBPP_lJjubg chao990613
Re: Correct Ballast for F20T9 & F30T8/CW/4 « Reply #1 on: January 11, 2020, 01:28:15 PM » Author: Men of God
您直接用120V 20W和30W的镇流器就行!
我不会英文,所以我用中文,请你们用翻译网站翻译我打的字!
I can't in English, so I in Chinese, please use the translation website to translate my words!
Re: Correct Ballast for F20T9 & F30T8/CW/4 « Reply #2 on: January 12, 2020, 12:17:13 AM » Author: xmaslightguy
Quote from: Mr. Orthosilicate
The F20T9 does operate  on a standard choke ballast for F20T12 lamps.
(I've also had a F20T9 work fine on a F20 RS ballast)
I'm not sure on the the F30"T8/CW/4 ... but I bet it'd run fine on the common F15T8-through-F20T12 chokes they make
musictomyeyes
Re: Correct Ballast for F20T9 & F30T8/CW/4 « Reply #3 on: June 18, 2020, 08:27:05 PM » Author: musictomyeyes
My wrong guess:
Like for F17T8, to use (F30T8·CW·4 19W, or F18T8/CW/K/30) with a simple reactance choke on 120V mains, it will require long preheat period; either: manual preheat, a starter FS-25, or electronic starter.  Ordinary FS-2 will struggle to ignite this appliance lamp.  A 2-lamp, low power factor, trigger start ballast could not ignite it, I doubt any single lamp trigger start ballast could ignite it.  I should try a HPF 2-lamp trigger start ballast.
Revised after testing:
Yes, a starter FS-2 and simple reactance choke ballast succeeds to strike and run F30'T8/CW/4, and so does HPF Trigger Start 2-lamp ballast Universal 564-L-TC-P.
« Last Edit: June 20, 2020, 10:41:08 PM by musictomyeyes » Logged
