Author Topic: Plant a lamp?  (Read 2990 times)
SeanB~1
Plant a lamp? « on: December 13, 2008, 12:00:01 AM » Author: SeanB~1
Got this from Daily Giz Wiz. http://plantalamp.net/ which turns an ordinary indoor plant into a touch dimmer. Costs $30, might be a good present if the recipient like lighting and has green thumbs.
TudorWhiz
Re: Plant a lamp? « Reply #1 on: December 14, 2008, 07:47:25 AM » Author: TudorWhiz
I TOTALLY believe it that it would work! Why? Well I did a test (knowing exactly what I was doing, don't play with electricity if you dunno what you are doing....but I was outside I tested a volt meter using an outlet and a bush next to it and use those to test voltage, the voltage was lower than 120 but it did make a good effect!
SeanB~1
Re: Plant a lamp? « Reply #2 on: December 14, 2008, 11:38:00 AM » Author: SeanB~1
Jace, you did tell me I had planted some lamps....... :D ;D
Hmmm remind me? Bulbs??? Tulip flowers? the 5 billion African dollars?
« Last Edit: December 14, 2008, 12:41:39 PM by TudorWhiz » Logged
