Author Topic: 1kw HPS/MH Ballast wiring help and can this run MV  (Read 2790 times)
Bulbhead500w
120 Volt/60 Hertz
1kw HPS/MH Ballast wiring help and can this run MV « on: September 25, 2019, 02:45:08 AM » Author: Bulbhead500w
What was this ballast used for.
Re: 1kw HPS/MH Ballast wiring help and can this run MV « Reply #1 on: September 25, 2019, 05:59:19 AM » Author: Medved
You would have to double check the nominal arc current: If the MV has about the same (MV could have 25% higher or 10% lower rating than these lamps) as the rated lamps, it will work, of ocurse with the ignitor disconnected.
Re: 1kw HPS/MH Ballast wiring help and can this run MV « Reply #2 on: September 25, 2019, 09:12:53 AM » Author: sox35
Hmmm, I'm thinking the other way around. I have a 1kW MV ballast (7.5A current on 240V), I'm wondering if I could run an HPS or MH lamp on it, with a suitable ignitor of course.
Rich, Coaster junkie!
Re: 1kw HPS/MH Ballast wiring help and can this run MV « Reply #3 on: September 25, 2019, 09:57:59 AM » Author: AngryHorse
Technically it will run both, but it would under run the SON by about 3 amp?
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
