Author Topic: 25KVA 7200 Primary 120/240 Secondary Pole Transformer  (Read 3357 times)
GE101R
25KVA 7200 Primary 120/240 Secondary Pole Transformer « on: September 21, 2019, 05:57:45 PM » Author: GE101R
Got this years ago to make jacob's ladders but never got around to it.
Re: 25KVA 7200 Primary 120/240 Secondary Pole Transformer « Reply #1 on: September 21, 2019, 10:00:10 PM » Author: xmaslightguy
Cool.
Maybe you could also use it to make an 'ultimate EOL lamp fryer'
Re: 25KVA 7200 Primary 120/240 Secondary Pole Transformer « Reply #2 on: September 22, 2019, 02:05:45 AM » Author: wide-lite 1000
you could make one hell of a bug zapper with that !
Re: 25KVA 7200 Primary 120/240 Secondary Pole Transformer « Reply #3 on: September 22, 2019, 02:51:20 AM » Author: HomeBrewLamps
I need one of these. Instead of frying lamps they'd probably just go boom
*evil laugh*
~Owen
Re: 25KVA 7200 Primary 120/240 Secondary Pole Transformer « Reply #4 on: September 22, 2019, 01:38:51 PM » Author: Ash
Without ballasting on the primary, this will be able to dead short your supply when you short the secondary. Actually, without ballasting it will most likely trip your breakers just with its magnetization inrush alone
So you must ballast it. And when you do, the secondary current is limited according to the turns ratio. With a 30A heating element array as ballast on the primary, secondary will be limited to 1A..
Re: 25KVA 7200 Primary 120/240 Secondary Pole Transformer « Reply #5 on: September 22, 2019, 03:29:31 PM » Author: Ash
You are going to use it to arc across the 7200V output. Without ballasting this is equivalent to a dead short
