Author Topic: What is this? (SimpleSet)  (Read 2149 times)
M250R201SA
JGriff021985 JMG717
What is this? (SimpleSet) « on: April 25, 2019, 10:21:19 PM » Author: M250R201SA
I have a Leotek GCJ, and it has a little blue strip on the Adam Driver.  I am wondering if this is for the Control Ready option that I ordered.
« Last Edit: April 25, 2019, 10:24:40 PM by M250R201SA » Logged
Re: What is this? (SimpleSet) « Reply #1 on: April 25, 2019, 10:42:02 PM » Author: wattMaster
It almost looks like a NFC strip for communicating with your phone, you might be able to change it.
« Last Edit: April 25, 2019, 10:44:34 PM by wattMaster » Logged
M250R201SA
JGriff021985 JMG717
Re: What is this? (SimpleSet) « Reply #2 on: April 26, 2019, 03:25:14 PM » Author: M250R201SA
I believe you may be correct.  However, I don’t seem to be able to find the software to modify it.  This luminaire is a CR (Control Ready) meaning utilities have the power to dim or brighten it.
Re: What is this? (SimpleSet) « Reply #3 on: April 26, 2019, 06:31:41 PM » Author: wattMaster
I did some extra searching and it's so the manufacturer can use 1 driver for many fixtures. The software seems to be some super exclusive thing that only fixture makers can really use, so that's why you can't find the software.
« Last Edit: April 26, 2019, 06:37:32 PM by wattMaster » Logged
M250R201SA
JGriff021985 JMG717
Re: What is this? (SimpleSet) « Reply #4 on: April 29, 2019, 02:29:24 PM » Author: M250R201SA
My other Leotek LED Fixture, a GCJ0-15H-MV-NW-2R-GY-350-PCR7 does not have a simple set, but it has different color-coded wires that enable me to adjust the wattage from 350mA to 700mA.  However, I took the terminal out, and installed it in my GCJ1-20H-MV-WW-5-GY-580-PCR7-CR-L10V-RWG, however, I am unable to change the wattage on that particular one, since it is a Control Ready fixture.  (meant to be changed wirelessly via a Node)
