January 18, 2025, 12:36:24 AM
General
HELP! Stuck Metal
Topic: HELP! Stuck Metal (Read 3156 times)
HELP! Stuck Metal
« on: April 11, 2019, 01:32:57 PM »
My bulb mold is having some problems. The top part got stuck in the main tube, and the aluminum oxide seems to have caused the jamming. Is there a good way to get it out?
Link to the bulb mold
SLS!
(Stop LED Streetlights!)
Re: HELP! Stuck Metal
« Reply #1 on: April 12, 2019, 10:46:34 PM »
Bump!
SLS!
« Reply #2 on: April 12, 2019, 11:02:26 PM »
Have you tried heating the main tube, it might expand enough to increase the clearance and allow removal. I don't know if it will work in this case but I done it a bunch of times with cars, from separating exhaust pipes to removing wheel bearings, a little (or a lot!) of heat goes a long way !
« Reply #3 on: April 13, 2019, 04:34:13 PM »
I tried chilling down the inner part with some upside-down compressed air, but it didn't help. I could try spraying the stuck part with a pressure washer or use some pliers to twist it apart. Any other ideas?
SLS!
« Reply #4 on: April 14, 2019, 10:37:13 AM »
Push!
SLS!
« Reply #5 on: April 15, 2019, 10:42:27 AM »
Force! Any ideas?
SLS!
« Reply #6 on: April 17, 2019, 09:16:22 PM »
Explode! I'll post this until I get an answer.
SLS!
« Reply #7 on: April 20, 2019, 10:33:33 PM »
Breaking news! I figured out how to get the mold apart (by using the hydraulic press as a vice and rotating the assembly with big pliers)
Bad news! I now have to make a rubber mold instead of a steel one, so now I need a good way to do that.
SLS!
