Author Topic: Is this a good mounting arm for outside?  (Read 2666 times)
Is this a good mounting arm for outside? « on: April 06, 2019, 09:53:40 AM » Author: Cole D.
I saw these on Amazon, in another post. It has the three bolt, which I think is sturdier than the Lithonia mounting arms, that don't have a through bolt. Also it says it's powder coated steel, and the shape looks like the American Electric arms. Although Amazon has another arm style for sale, it says it's for LED fixtures.
Designer's Edge Mounting Arm
fluorescent lover 40
Re: Is this a good mounting arm for outside? « Reply #1 on: April 06, 2019, 10:36:56 AM » Author: fluorescent lover 40
Yes, they are better arms as they have a thru bolt which prevents sagging. The Lithonias will sag over time.
lightinglover8902
GoL UCfoxh9h5FaLg-R04V8WDi3w
Re: Is this a good mounting arm for outside? « Reply #2 on: April 06, 2019, 11:27:01 AM » Author: lightinglover8902
I recommend a better arm with a thru bolt than that one.
Re: Is this a good mounting arm for outside? « Reply #3 on: December 12, 2019, 10:50:36 PM » Author: Cole D.
Unfortunately it seems these had been discontinued, which is shame. They look nicer than the other typical curved arms with no through bolting.
Re: Is this a good mounting arm for outside? « Reply #4 on: December 13, 2019, 03:19:53 PM » Author: Ash
Choose an arm that have long enough section tangent to the pole, and tie around this section with 2 steel bands
Re: Is this a good mounting arm for outside? « Reply #5 on: December 25, 2019, 09:25:43 AM » Author: Mandolin Girl
With a mounting arm, the important fixing is the top one as that takes most of the weight and has the most force applied by pressure from the arm itself, so must be securely fastened with a large lag bolt or a through bolt, then as has been said a long length down the pole, at least as long as the arm.
