January 31, 2025, 07:50:18 PM
General
General Discussion
How do you connect a fluorescent tube?
Topic: How do you connect a fluorescent tube? (Read 2262 times)
Binarix128
220V AC 50Hz, NTSC
« on: April 02, 2019, 04:33:27 PM »
Binarix128
You have andother way for connect a fluorescent tube in a magnetic ballast, or for connect in series or parallel?
o-
-o
o o
Re: How do you connect a fluorescent tube?
« Reply #1 on: April 02, 2019, 08:03:20 PM »
With switch start, you connect it just like your example (the attached picture). With HF ballast, you follow the wiring diagram on the label.
If you connect two lamps in series on a single choke ballast, you need a starter loop for each lamp. You can only do so on mains above 200V, however. For this to work, you will need 120V starters even though the mains are above 200 V.
If you connect two lamps in parallel (each having a starter loop) then only one will strike. This concept is sometimes used to extend the period between relamping visits.
Binarix128
220V AC 50Hz, NTSC
« Reply #2 on: April 03, 2019, 09:55:15 PM »
Binarix128
Thanks!
lightinglover8902
« Reply #3 on: April 06, 2019, 08:05:39 PM »
lightinglover8902
A diagram of the circuit (note: this is a pre-heat style circuit with a starter)
« Reply #4 on: April 07, 2019, 04:10:29 PM »
I think 2x 4W T5 might be able to work in series on 120V. However there are no suitable starters made (this would need "60V" starters)
In Instant Start setup, any number of FL tubes can be connected in series up to the max arc voltage the ballast can provide. Connect 1 or 2 pins at the tube end based on how close the supplied current is to the lamp's nominal current (1 pin is preferrable when the tube is underdriven)
