Author Topic: Rubidium lamps?  (Read 2335 times)
Rubidium lamps? « on: February 27, 2019, 09:30:03 PM » Author: wattMaster
How would they compare to regular sodium bulbs? Due to its high vapor pressure, it could work well. Also, potassium could be an option.
« Last Edit: February 27, 2019, 09:35:04 PM by wattMaster » Logged
Re: Rubidium lamps? « Reply #1 on: February 28, 2019, 04:56:19 AM » Author: dor123
I think rubidium would yield lower efficacy than sodium. That why caesium and potassium lamps weren't existed commercially, but only as engineering samples.
Re: Rubidium lamps? « Reply #2 on: February 28, 2019, 05:35:29 PM » Author: Lumex120
I'd like to see a lithium filled HPS (HPL?) lamp just since lithium is so pretty when it's energized.
Unofficial LG Discord
Re: Rubidium lamps? « Reply #3 on: April 01, 2019, 01:52:57 AM » Author: James
Lithium does not work in an HPS lamp, I have tried it without success!  The vapour pressure of this metal is just too low.  However Rubidium, Potassium and Caesium do all work, but have terribly poor luminous efficacy.  At very high loadings under pulse operation its possible to achieve about 40 lm/W, but standard HPS type lamps with caesium are only about half as efficient as incandescent lamps of the same rating.  If I remember rightly the best I ever achieved in a 600W caesium lamp was about 12 lm/W!  Beautiful colour white light of very high CRI though.
Re: Rubidium lamps? « Reply #4 on: April 01, 2019, 03:24:16 AM » Author: Medved
Isn't that result of a fact the arc being then more of a a Planck black body type than a quantum excitation-emission type radiator?
