Author Topic: Do you collect other things besides lighting??  (Read 48385 times)
Re: Do you collect other things besides lighting?? « Reply #120 on: November 06, 2020, 12:35:21 AM » Author: joseph_125
It looks to be a fairly capable machine for a dual cassette deck. It has Dolby B and C and also more importantly it has a bias control which most tape decks don't have. The next step up would be a 3 head tape deck that lets you record and monitor the recording at the same time. 3 heads also have the advantage of the play and record heads being gapped differently to better suit their functions instead of a combined play/record head on a two head deck.
BTW if you're planning on getting a tape deck you plan on changing the belts in, I would see if you can find the service manual as you can judge how difficult it is to change the belts as well as make it a lot easier to do the job.
Re: Do you collect other things besides lighting?? « Reply #121 on: November 06, 2020, 06:29:11 AM » Author: sox35
It is a 3-head deck, you can monitor recordings fine. I just wish it was possible to record on both decks instead of just one.
Fluorescent05
Zack
Re: Do you collect other things besides lighting?? « Reply #122 on: November 06, 2020, 10:21:04 AM » Author: Fluorescent05
That sounds like a great option then! Sox35 also said it has 3 heads on the recording deck. I don't mind the fact that only one deck records. Does the recording deck record only forward or reverse too (Because it is an auto reverse machine)? Also, what is relay playback (on the reverse mode switch)?
« Last Edit: November 06, 2020, 10:31:23 AM by Fluorescent05 » Logged
Re: Do you collect other things besides lighting?? « Reply #123 on: November 06, 2020, 11:57:05 AM » Author: sox35
It has auto-reverse and the recording deck records both ways as well. Not sure on relay playback, will have to dig out the manual.
Fluorescent05
Zack
Re: Do you collect other things besides lighting?? « Reply #124 on: November 06, 2020, 12:05:06 PM » Author: Fluorescent05
Do you have the service manual? I can't seem to find it online but it will be almost necessary to read before replacing the belts if I end up getting the one on eBay. I did end up finding the user manual (very dumbed down, no service instructions) and it says that relay play will play both sides of the deck you press play on then both sides of the other deck. Also, online it says that deck 2 has one head for both record and play.
Re: Do you collect other things besides lighting?? « Reply #125 on: November 06, 2020, 12:06:11 PM » Author: sox35
No I don't have the service manual, might be able to find it online somewhere though.
Re: Do you collect other things besides lighting?? « Reply #126 on: November 06, 2020, 03:45:30 PM » Author: joseph_125
Hifi Engine has it but you'll need to sign up for their site. I can't seem to find one that isn't behind a pay or sign up wall though.
Apparently relay playback lets you play between both sides on decks 1 and 2 continuously. I guess it's intended for background music since you can get 3 hours of continuous music with two 90 min tapes. 4 or even 6 hours if you're willing to use the more fragile 120 and 180 min tapes.
Fluorescent05
Zack
Re: Do you collect other things besides lighting?? « Reply #127 on: November 06, 2020, 06:27:28 PM » Author: Fluorescent05
The user manual explicitly says not to use the 120 minute tapes because they are too thin (and easily get stuck around the capstans and pinch rollers), but it doesn't mention the 180 minute tapes. I would assume those would be even worse though.
Re: Do you collect other things besides lighting?? « Reply #128 on: November 07, 2020, 06:01:22 AM » Author: Mandolin Girl
I only ever use the 60 min or 90 min tapes.
Re: Do you collect other things besides lighting?? « Reply #129 on: November 07, 2020, 06:43:12 AM » Author: Mandolin Girl
The VHS player I bought at the same time as my first hi fi was by the same maker and could be used as an audio tape recorder, so with a E240 tape I could get eight hours if using the long play setting.  8)
Normally that would be quite long enough for a party...  :wndr:
But I had one that lasted from 19:30 on Friday evening until 16:00 the following Friday.! :laugh:
Fluorescent05
Zack
Re: Do you collect other things besides lighting?? « Reply #130 on: November 07, 2020, 01:30:18 PM » Author: Fluorescent05
You had a Denon VCR that could record audio onto a VHS tape that lasted an entire week? :poof:
« Last Edit: November 07, 2020, 01:32:33 PM by Fluorescent05 » Logged
Re: Do you collect other things besides lighting?? « Reply #131 on: November 07, 2020, 01:33:31 PM » Author: Mandolin Girl
You had a Denon VCR that could record audio onto that lasted an entire week? :poof:
It was a Pioneer branded Philips machine that recorded for eight hours.
The party lasted for a week, my parents said I could have one party while they were on holiday...  :D
Fluorescent05
Zack
Re: Do you collect other things besides lighting?? « Reply #132 on: November 07, 2020, 02:21:46 PM » Author: Fluorescent05
That's still cool! Couldn't you just record audio onto the video part of the tape and play it back in any VCR with the speaker connected to the video output?
Re: Do you collect other things besides lighting?? « Reply #133 on: November 07, 2020, 02:25:51 PM » Author: sox35
I suppose I could have, but as it was a stereo VHS recorder and was in the rack of hi fi kit I made use of it.  :wndr:
The CD player took cartidges loaded with six CDs so I had ample choices for long playing sessions.  8)
Re: Do you collect other things besides lighting?? « Reply #134 on: November 07, 2020, 02:29:10 PM » Author: sox35
Actually no, you couldn't. The composite video output would be 1V peak-to-peak and a speaker wouldn't like it much. I don't think audio fed into the video input would go down too well either..!
« Last Edit: November 07, 2020, 02:37:32 PM by sox35 » Logged
