Author Topic: Unassembling a magnetic ballast  (Read 12382 times)
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Unassembling a magnetic ballast « on: August 27, 2008, 04:55:07 PM » Author: Foxtronix
I found recently a GE ballast (with silver label) that it smokes when plugged, so useless. I'm wondering: is only a specific part filled with oil or the WHOLE ballast?
form109
Re: Unassembling a magnetic ballast « Reply #1 on: August 27, 2008, 05:33:08 PM » Author: form109
are you talking about a flourescent ballast.
Foxtronix
Re: Unassembling a magnetic ballast « Reply #2 on: August 27, 2008, 09:54:17 PM » Author: Foxtronix
yeah a fluorescent ballast
form109
Re: Unassembling a magnetic ballast « Reply #3 on: August 27, 2008, 09:56:31 PM » Author: form109
i tried disassembling a flourescent ballast,it was difficult because the components of the ballast were potted in tar.
Foxtronix
Re: Unassembling a magnetic ballast « Reply #4 on: August 27, 2008, 10:16:41 PM » Author: Foxtronix
Tar? What is this?
SeanB~1
Re: Unassembling a magnetic ballast « Reply #5 on: August 28, 2008, 01:33:51 PM » Author: SeanB~1
Older ballasts were encapsulated in bitumen ( the same stuff applied to roads, but without the stones) and some sand as filler. More modern ballasts are encapsulated in an epoxy resin. The reason is to reduce hum and noise, as well as providing moisture proofing and environmental protection. The encapsulation also aids with heat transfer from the internal components to the case, as well as preventing the thin internal wiring from breaking due to movement from magnetic fields.
As a bonus for the manufacturer, it makes the ballast unrepairable. To easily depot place the ballast overnight inside a plastic bag inside a freezer ( or outdoors in Canada in winter) so as to make the bitumen so hard that it shatters like glass when hit, enabling you to remove the casing without damaging it for retrofitting a more modern interior whilst retaining the old style looks.
Foxtronix
Re: Unassembling a magnetic ballast « Reply #6 on: August 28, 2008, 02:35:16 PM » Author: Foxtronix
Ok thanks. If I understood, when frozen, the bitumen are breakable and I can take the transformers for making preheat ballasts right?
