Author Topic: Dis functional powergroove help  (Read 2064 times)
ramdude2014
Dis functional powergroove help « on: November 15, 2018, 04:48:23 PM » Author: ramdude2014
I fear my f96pg17 is forever dead but all it does is flicker very dim and ends light up orange! Is there a way to maybe heat it up and maybe work again... its brand new and only worked a couple times!!
Next stop gate T17!
Re: Dis functional powergroove help « Reply #1 on: November 16, 2018, 03:44:44 AM » Author: Ash
Is your gear ok ? A dead capacitor in Rapid Start can do things like this
Also maybe the tube or gear are borderline for starting anyway and last time it worked you had a little higher line voltage or higher temperature in the room, or the lamp was laying on a surface that assisted starting, or some similar conditions change
