Author Topic: Will 13 watt PL-L (2G11 base) work on magnetic RS ballasts?  (Read 2069 times)
Fluorescent05
Zack
Will 13 watt PL-L (2G11 base) work on magnetic RS ballasts? « on: November 09, 2018, 10:57:05 AM » Author: Fluorescent05
Will an Advance LQ-206F-TP magnetic RS ballast (2 lamp F4, F6, or F8T5) work to power 13 watt 2G11 PL lamps?
Re: Will 13 watt PL-L (2G11 base) work on magnetic RS ballasts? « Reply #1 on: November 09, 2018, 12:51:50 PM » Author: dor123
PLs have usually krypton gas, which have higher starting and restriking voltage than the OCV of rapid-start ballasts. I don't know if this is the case with the American PL-S 13W
Never heard about 13W PL-L. The lowest wattage of PL-L available is 18W.
Danny
Re: Will 13 watt PL-L (2G11 base) work on magnetic RS ballasts? « Reply #2 on: November 09, 2018, 02:28:43 PM » Author: Danny
In the uk the same ballasts that are marked for F4T5, F6T5 and F8T5s will also happily light 5w, 7w, 9w and 11w PL-S lamps and the 13w USA Ones i have
Fluorescent05
Zack
Re: Will 13 watt PL-L (2G11 base) work on magnetic RS ballasts? « Reply #3 on: November 09, 2018, 02:39:41 PM » Author: Fluorescent05
Not in the US. US made PL-L lamps have argon fill gas.
