wal mart seems to group re lamp which works better for dimming applications. the point is to keep "lighting uniformity" with lamps of the same age. I noticed the lamps rectify at high frequency when dimmed,when they increase in brightness the EOL protection must sense the rectification. I really need to go there on a sunny day and take pics.
Some lamps on some dimmers are rectifying when on low settling, while this phenomenon disappear on higher power levels.
It might have three reasons:
1) The lamp is close to EOL and when the cathode temperature is controlled mainly by the external power and not by the cathode fall dissipation (so on low power setting), the difference in emission might become significant.
2) The ballast is (by it's internal mismatch) on low setting not able to equally heat both cathodes or heat them not enough (so where the emission-temperature dependence is steep, so small temperature difference cause large emission difference)
3) It is very frequent practice to add a small DC current (resistor in parallel with one DC blocking capacitor) to the lamp, as it make the arc much more stable at low dimming levels. This might demonstrate on really low settings equally as lamp rectification (mercury migration).
Case 1) appears only on worn-out lamps and is not an issue.
Case 3) appear on all lamps, but only on very low settings (below 10%, usually at ~1..5%)
Case 2) is the only to worry about, as such ballast heavily damage electrodes at low setting...
Usually dimmable ballasts (with below 20..30% level dimming capability) need quite complex control schemes, so use dedicated controllers, with usually already build in EOL protections...
