Author Topic: When did T8 tubes come out?  (Read 7646 times)
halofosfaatti
When did T8 tubes come out? « on: November 02, 2018, 05:38:20 AM » Author: halofosfaatti
I have wondered when they come out.
Too many things are secret. Only open information can really preserve old technology.
I like fluorescent and other conventional lighting and old electronic equipment. Today's things are not made to last.
Re: When did T8 tubes come out? « Reply #1 on: November 02, 2018, 06:08:00 AM » Author: dor123
I think during the 80's: http://www.lamptech.co.uk/Documents/FL%20Gases.htm
The Americans also have T8 tubes, but they are completely different lamps than ours.
halofosfaatti
Re: When did T8 tubes come out? « Reply #2 on: November 02, 2018, 06:52:30 AM » Author: halofosfaatti
Ok. What is the differences beetween European and American tubes?
« Last Edit: November 02, 2018, 07:52:45 AM by halofosfaatti » Logged
Re: When did T8 tubes come out? « Reply #3 on: November 02, 2018, 09:56:14 AM » Author: dor123
European T8 have krypton buffer gas, and intended to replace T12 on their series chokes. They are available at 18W (For 20W T12), 36W (For 40W T12) and 58W (For 65W T12).
American T8 have argon gas, and requires a dedicated ballast for them, and aren't intended to retrofit for T12 lamps on their ballast (Otherwise they would be overdriven). Available in various wattage ratings, most commonly 32W, which have the same length as 40W T12.
Re: When did T8 tubes come out? « Reply #4 on: November 02, 2018, 10:28:04 AM » Author: funkybulb
GE started making T8 even back in it Heyday
anyway the 32 watt and 17 watts lamps  came out
in early 1980s.  but preheat T8 been around. for a good
while.
halofosfaatti
Re: When did T8 tubes come out? « Reply #5 on: November 02, 2018, 01:06:29 PM » Author: halofosfaatti
Ok.
Re: When did T8 tubes come out? « Reply #6 on: November 02, 2018, 03:39:28 PM » Author: sol
The F15T8 and the F30T8 were the first two commercially available fluorescent lamps. They were invented as we know them in 1934 and were put on the market in 1938. The F20T12 was next to follow and then the F40T12. All of those ran on preheat circuits.
I believe in the USA, when they came out, you needed to use 220V for the F30. Within a year or two, autotransformer ballasts became available for 110V applications. (Those mains voltages were the North American standard before being raised to 120 and 240.)
Re: When did T8 tubes come out? « Reply #7 on: November 02, 2018, 04:51:36 PM » Author: Roi_hartmann
If 15w t8 was there right from the beginning what was the point of 15w t12 lamps?
Michael
Re: When did T8 tubes come out? « Reply #8 on: November 03, 2018, 03:50:31 AM » Author: Michael
The T8 18/ 36/ 58W came around 1978. Later in the 80s other wattages in T8 format like 14W/ 23W/ 36W-1m/38W and 70W were introduced to replace T12 format of 14W/ 25W/ 40W-1m/ 42W and 75-85W(british) tubes.
The 15W and 30W T8 Ar- buffered tubes were on the market since the beginning.
For the european U shaped tubes like those from Osram GmbH the change to T8 was in the mid nineties.
« Last Edit: November 03, 2018, 03:56:09 AM by monkeyface » Logged
Re: When did T8 tubes come out? « Reply #9 on: November 03, 2018, 04:06:32 AM » Author: dor123
I don't know about the 14W, 23W, 36W-1m and 38W T8s and the 14W, 25W, 40W-1m and 42W T12. I know that the British only have the 70W T8 that retrofits 75-85W T12 and the 100W T12 which retrofits the 125W T5.
halofosfaatti
Re: When did T8 tubes come out? « Reply #10 on: November 03, 2018, 06:16:55 AM » Author: halofosfaatti
Some sources say that T12 tubes do not need very pure and expensive phosphors that T8 tubes need (due to proximity of arc?). Newer triphosphor mixtures are not very sensitive to the arc, but they are more expensive and using T8 helps to reduce costs and achieving needed electrical characteristics.
Re: When did T8 tubes come out? « Reply #11 on: November 03, 2018, 06:20:17 AM » Author: dor123
T8 uses the same phosphors as the T12. These are the long T5 and the CFLs which requires the triphosphors, since they operates at much higher loading than T8 and T12, so the halophosphors would fade much faster on them.
Re: When did T8 tubes come out? « Reply #12 on: November 03, 2018, 01:48:17 PM » Author: dor123
Oops. I meant 125W T12, not T5.
MissRiaElaine
Re: When did T8 tubes come out? « Reply #13 on: November 08, 2018, 09:40:25 AM » Author: MissRiaElaine
I first remember seeing T8 tubes here in the late 60's/early 70's, my next door neighbour who was an electrician had one in his living room. I thought then that they looked weird compared to T12's, which I still think are the best tubes ever, especially the BC capped ones  ;D
Michael
Re: When did T8 tubes come out? « Reply #14 on: November 08, 2018, 01:15:15 PM » Author: Michael
Dor, there was in fact a T5 tube available with 120W as well a 95W version. Both of them were introduced onto the market by Philips as high bay VHO lamps after the 2008 light& building fair.  8)
